[Submitted] Oneplus 9 pro os stuck
  1. Nakata24
    Froyo May 4, 2021
    Nakata24 , May 4, 2021 :
    After closing netflix with the power button, sometimes the pohne will stuck.
    https://photos.app.goo.gl/p57kb7KyvQJCEjQ29
    Here is a link to check out. Its not always but i had this 3 times already. Hard with volume+power button will reboot and fix.
    Also if you watching something on netflix or facebook insta tiktok and you close it with the power button, the sound will sometimes pop up while the screen is off.
  2. Prashanth 27
    OnePlus Bug Hunter Staff Member May 5, 2021
    Prashanth 27 , May 5, 2021 :
    We may have to check this further. Kindly check you're inbox we've dropped you a direct message. It'll be of great help if you could share the required information.
    Regards,
    Prashanth.
  3. kkrisdal
    Eclair May 20, 2021
    kkrisdal , via OnePlus 9 , May 20, 2021 :
    The same happens in my oneplus 9 but I don't need to use Netflix ant phone don't p
    blink. When I open recent apps list I cannot swipe them away.. and when I go to settings the menu gets stuck.. cannot scroll down or up in the menu.... Help. only thing that helps is e reboot. I tried to remove oneplus launcher updates to se if that was the issue.
