4
Oneplus 9 Pro PC connectivity issue on USB type C to Type C
  1. G_Ganesh_venki_axUf
    Gingerbread Jul 27, 2021
    G_Ganesh_venki_axUf , via OnePlus 9 Pro , Jul 27, 2021 :
    But the same c2c cable worked fine in my gaming desktop though.
    I think it is something related to OnePlus which is restricting the phone to detect the laptops??
    Or I am not sure though.
    #41
  2. blueskywhale
    The Lab - OnePlus 9 Pro Reviewer Jul 27, 2021
    #42
  3. Caomhin
    OnePlus 9 Series Expert Community Expert Jul 27, 2021
    Caomhin , via OnePlus 9 Pro , Jul 27, 2021 :
    My 9 Pro connects fine on my laptop, make sure you have installed the Qualcomm drivers and check device manager on the laptop to see if there are any driver issues after connecting.
    Also check this website to see if any of the suggestions can help.
    https://www.makeuseof.com/tag/fixes-android-connect-computer/
    #43
  4. G_Ganesh_venki_axUf
    #44
  5. Swejuggalo
    Swejuggalo , via OnePlus 9 Pro Stellar Black , Jul 27, 2021 :
    Some may need a USB 3.1 Gen1 cable to get stable connections. The cable that come with is USB 2.0.
    Some computers seems to be more cranky than others about the speed.
    #45
  6. blueskywhale
    blueskywhale , Jul 27, 2021 :
    So this is the note we are talking about.. then the C to C cable sold separately will work right ??..
    #46
  7. Swejuggalo
    #47
  8. G_Ganesh_venki_axUf
    Gingerbread Aug 4, 2021
    G_Ganesh_venki_axUf , via OnePlus 9 Pro , Aug 4, 2021 :
    No stock cable is not only for charging. It does transfer files in the desktop. Only with laptop it is not detecting.
    My guess is , 9 pro is considering the laptop port only as the power source not the data transfer hub.
    #48
  9. Swejuggalo
    OnePlus 9 Series Expert Community Expert Aug 4, 2021
    Swejuggalo , via OnePlus 9 Pro Stellar Black , Aug 4, 2021 :
    Well... It "can" connect for data perfectly fine for many. But if the computer insists on trying to run 3.1 GEN1 speeds on it it will fail and might disconnect. So this can make it work fine on some ports but bad on others. A real 3.1 GEN1 cable would surely make it work on the laptop too.
    #49
  10. G_Ganesh_venki_axUf
    Gingerbread Aug 6, 2021
    G_Ganesh_venki_axUf , via OnePlus 9 Pro , Aug 6, 2021 :
    It is the same spec on my laptop and in my desktop. Still fails in laptop in c to c port. Works in type A to c though.
    In desktop works on both cables
    #50
  11. Swejuggalo
    OnePlus 9 Series Expert Community Expert Aug 6, 2021
    Swejuggalo , via OnePlus 9 Pro Stellar Black , Aug 6, 2021 :
    Seen similar differences between computers. Some work some don't of some reason. Various types of controllers may be a factor.
    #51
  12. Jay_Khatri
    Cupcake Sep 23, 2021
    Jay_Khatri , via OnePlus 9 Pro , Sep 23, 2021 :
    Having the same issue with my 9 pro. Tried using a different c-c cable, same problem.
    Works with USB c-a but not the included c-c.
    Definitely a bug. Please help.
    #52
    G_Ganesh_venki_axUf likes this.
  13. Swejuggalo
    OnePlus 9 Series Expert Community Expert Sep 23, 2021
    Swejuggalo , via OnePlus 9 Pro Morning Mist , Sep 23, 2021 :
    Is your A ports USB 2.0? How about your C port? Any 3.1 GEN1 cable available for testing? I have one of those to maximize connectivity (phone port is 3.1 GEN1.. Not the stock cable)
    #53
  14. Jay_Khatri
    USB A is 3.1 Port and C is also 3.1. It's not a cable issue because it works when using my OnePlus 5 but doesn't with the 9 pro
    #54
  15. Swejuggalo
    Well... Note that 5 has a USB 2.0 port and never need anything better than a USB 2.0 cable.
    Some have major issues depending on used port. Same speed port but on a other computer may work due to a different USB controller. So strange things happen.
    #55
  16. blueskywhale
    The Lab - OnePlus 9 Pro Reviewer Sep 23, 2021
    #56
  17. Jay_Khatri
    Cupcake Oct 9, 2021
    #57
  18. Pavan Bakle
    Cupcake Oct 20, 2021
    Pavan Bakle , via OnePlus 9 Pro , Oct 20, 2021 :
    Same issue with my OnePlus 9 Pro it just detects for a second and disappears I have tried in my friends laptop it works fine in his laptop but does not work properly in my laptop can't understand what is the exact issue
    #58
  19. Swejuggalo
    OnePlus 9 Series Expert Community Expert Oct 20, 2021
    Swejuggalo , via OnePlus 9 Pro Morning Mist , Oct 20, 2021 :
    Drivers / connection speed failing due to different behavior of the USB ports. Try a USB 3.1 GEN1 cable if you have one.
    #59
    Pavan Bakle likes this.
  20. Jay_Khatri
    Cupcake Oct 27, 2021
    Jay_Khatri , via OnePlus 9 Pro , Oct 27, 2021 :
    Atleast it's working for you on another laptop. I tried 8 different laptops from various manufacturers. No connection.
    #60
