4
OnePlus 9 pro - problem with pc connectivity
  1. G_Ganesh_venki_axUf
    Gingerbread May 15, 2021
    G_Ganesh_venki_axUf , via OnePlus 9 Pro , May 15, 2021 :
    Sad thing is no update from either OnePlus or from Lenovo.
    OnePlus should jump and check what is wrong here.
    #41
  2. G_Ganesh_venki_axUf
    #42
  3. G_Ganesh_venki_axUf
    #43
  4. webnizam
    Froyo May 15, 2021
    webnizam , via OnePlus 9 Pro , May 15, 2021 :
    I've just tried it, sadly it didn't work. May be it'll get fixed in next update.
    Thanks btw.
    Is there any update on Openbeta for OP9 series?
    #44
  5. G_Ganesh_venki_axUf
    I stick to stable, even stable is not stable anymore. So beta is like jumping ourselves from a 10 story building.
    No idea on that.
    #45
    webnizam likes this.
  6. webnizam
    Froyo May 15, 2021
    I didn't check it,i barely used Color OS, Flashed Oxygen right after i got it. But i remember, 5G was working in color os which is not functioning in oxygen right now.
    OnePlus is f*****d up with 9 series.
    #46
  7. G_Ganesh_venki_axUf
    I came back to OnePlus after a short spin with other brands.
    Sadly OnePlus is more buggy now a days.😟
    #47
  8. webnizam
    Froyo May 15, 2021
    Totally agree,
    But, It used to be fun back then, I've used op7 and 5t.
    Now it's all a mess.
    #48
    G_Ganesh_venki_axUf likes this.
  9. G_Ganesh_venki_axUf
    Effect of Carl pei leaving? Or I don't know.
    OnePlus should fix these sort of silly issues.
    These bugs are the one which makes the phone look cheap.
    This thread creator confirmed S21 is working fine with his legion. So I don't think this is a issue with Lenovo.
    This is a bug in OnePlus 9 pro for sure.
    #49
  10. Ultradyong
    Froyo May 16, 2021
    Ultradyong , via OnePlus 9 Pro , May 16, 2021 :
    I would advise waiting a while for an update to address the problem before updating the device, wait for people to comment on problem faces on the device before updating the phone.
    #50
  11. paramjit2001
    Gingerbread May 16, 2021
    #51
  12. mikemx55
    Cupcake Jun 1, 2021
    mikemx55 , Jun 1, 2021 :
    Facing the same problem as no notification would show up with USB-C cable connected to USB-C port on a DELL XPS 15 9550.
    I went into settings, searched "usb" then selected "USB Preferences", and it opened the various options all greyed out.
    It shows as the phone charging the laptop and the laptop also receives a notification that it is being charged with a low power adapter.
    When I try to press the toggle to disable charging, it just says "Switching" and then says "Couldn't Switch" and everything stays the same
    If I use an USB-A port it works fine as expected.
    #52
  13. Caomhin
    OnePlus 9 Series Expert Community Expert Jun 1, 2021
    Caomhin , via OnePlus 9 Pro , Jun 1, 2021 :
    Please send Feedback on the issues back to the OnePlus OOS developers. So that they can investigate them. Thank you.
    Community App Feedback tool
    #53
  14. Ultradyong
    Froyo Jun 4, 2021
    #54
  15. rmarratzu
    Cupcake Jun 12, 2021
    rmarratzu , Jun 12, 2021 :
    First, connect your OnePlus to a PC via USB. It will start charging.
    Then on your phone go to Settings, and search for "USB".
    Select "USB Preferences", then select "File Transfer". (By default it is set to "No Data Transfer".)
    After that, you will be able to transfer your files from/to your OP and your PC easily.
    #55
  16. Naga Rajan
    Eclair Jun 12, 2021
    Naga Rajan , via OnePlus 9 Pro , Jun 12, 2021 :
    Seriously ? Even after switching to file transfer nothing shows up in the pc. That's what the problem is.
    #56
  17. rmarratzu
    rmarratzu , via OnePlus 9 Pro , Jun 12, 2021 :
    Hey, we are just trying to help.
    I had the same problem and what I wrote worked for me.
    I understand it's not the same for you. I assume you have already checked your PC and antivirus settings.
    Anyway, good luck.
    #57
  18. Naga Rajan
    Eclair Jun 12, 2021
    No actuly the problem is, it not shows up in pc even after switching to file transfer. Tried switching cables also. Other devices are perfectly working to transfer files even with 9 pro's cable. So there is no issues with cable, laptop or usb ports either. The problem is with 9 pro. That's why I raised this issue.
    #58
  19. Naga Rajan
    Eclair Jun 12, 2021
    And i haven't checked this after the last update. Will check and let you know that also
    #59
  20. Ultradyong
    Froyo Jun 13, 2021
    Ultradyong , via OnePlus 9 Pro , Jun 13, 2021 :
    Hopefully all this issues will be resolve by a software update for your device soon, as I don't get this problem, hopefully OnePlus Research and Development team can resolve the issues that all of you face as soon as possible.
    #60
