8
OnePlus 9 Pro PUBG 90 Fps issue
  1. zeroxoverflow
    Donut May 21, 2021
  2. paulnirappil
    Cupcake May 27, 2021
    paulnirappil , via OnePlus 8 Pro , May 27, 2021 :
    You should have more patience. Give the developers some time to work on it. Probably it will be rolled out in 3 4 months. even the gaming phones like Black shark 4 & Rog 5 doesn't have the option yet.
  3. G_Barak_D
    Froyo May 27, 2021
    G_Barak_D , May 27, 2021 :
    What about hyper touch in codm? This phone marketed as supporting hyper touch in this game. In reality it does not at the moment.
  4. Q1616401210534
    Cupcake May 30, 2021
    Q1616401210534 , May 30, 2021 :
    Same bro
  5. the_o2
    OnePlus 9 Series Expert Community Expert May 31, 2021
    the_o2 , May 31, 2021 :
    It is same for every device who have SD888 processor.
  6. T1628181227364
    Cupcake Aug 5, 2021
    T1628181227364 , Aug 5, 2021 :
    asus rog5 got 90fps with same exact processor of op9pro...why delaying one oneplus phones?
  7. the_o2
    OnePlus 9 Series Expert Community Expert Aug 6, 2021
  8. F1625459983433
    Cupcake Aug 11, 2021
    F1625459983433 , via OnePlus 9 Pro , Aug 11, 2021 :
    Even though pubg has enabled the 90fps option for OnePlus 9 series.it is still not showing the option in the fps settings.can anybody tell me if it will ever work with OnePlus 9 pro?
  9. Swejuggalo
    OnePlus 9 Series Expert Community Expert Aug 11, 2021
    Swejuggalo , via OnePlus 9 Pro Stellar Black , Aug 11, 2021 :
    I heard rumors that they tried it but removed it for 9 Pro again. It probably need slightly different profile/support due to the Smart 120 vs the Auto 120 on the regular 9.
    MythicalAnimal likes this.
  10. MythicalAnimal
    Honeycomb Aug 11, 2021
  11. Swejuggalo
    Tried it and have it working? Regarding both PUGB and BGMI I see 3rd party sites with lists that sometimes don't seem to match what users have. Also keep in mind that PUGB and BGMI may support it at slightly different times since one is Tencent and one is Krafton.
  12. MythicalAnimal
    MythicalAnimal , via OnePlus 9 Pro , Aug 11, 2021 :
    Haven't tried it.
    Will patiently wait for official release, hoping to get it sooner.🤘
  13. Swejuggalo
    You where refering to the config files before then?
    Apparently it refers to folders that is not accessible... Unless rooted. At least not on PUGB and 9 Pro....
    Question is...if that works flawlessly. Why not officially supporting it?
    PUGB does not work at 90 fps on my phone. And not use the config file either. And some on 9 that had it working ends up with 90 fps but running it at 60 Hz 😉
  14. rolkabolka
    Cupcake Aug 19, 2021
    F1627999579529 likes this.
  15. K1629545544871
    Cupcake Aug 26, 2021
  16. MythicalAnimal
    Honeycomb Sep 3, 2021
  17. Yatharth05
    Cupcake Sep 7, 2021
    Yatharth05 , via OnePlus 9 Pro , Sep 7, 2021 :
    That is not really the problem. First of all 90 fps is not really useful because when you are playing the fps stays at about 60 fps. Now getting back to the problem so the real problem is actually a feature of OnePlus 9 pro and that is the smart refresh rate as i already mentioned when you are in the game the fps stays around 60 fps and the game's software think's that your phone doesn't support 90 fps because it doesn't have 90 hz refresh rate but in reality because of smart refresh rate your device is only refreshing the screen at 70hz that is the reason why games or particularly pubg mobile think's your device doesn't have 90hz refresh rate.
    #38
  18. Swejuggalo
    OnePlus 9 Series Expert Community Expert Sep 7, 2021
    Swejuggalo , via OnePlus 9 Pro Stellar Black , Sep 7, 2021 :
    Regular 9 apparently supports 90 fps mode but for many it seems to run the game at 60 Hz. It can only use 60 Hz and 120 Hz while 9 Pro can use multiple.
    Either way fps and Hz is not necessarily in sync and depending on each other. Question is... What will it take to get 9 Pro supported?
    #39
    Darshit611 likes this.
  19. Yatharth05
    Cupcake Sep 7, 2021
    Hey bro,
    Sorry but i didn't quite understand your comment.
    Secondly the answer to your question "what will it take to get the 9 pro supported" is that either OnePlus add another option of constant 120 hz refresh rate or pubg making some changes in their software to detect that the device deos indeed have 90 hz refresh rate in this case OnePlus 9 pro have a 120 hz refresh rate so no problem there.
    #40
