Oneplus 9 pro System sound settings via OnePlus 9 Pro Morning Mist
  1. Kraverine , via OnePlus 9 Pro Morning Mist , Sep 29, 2021 :
    Is there any way to differentiate the system sound and media sound. Like if i increase the media volume the sound would be high for every song/video which is kinda annoying what i want it high volume for keypad noise/screen lock sound/camera click etc. But if i want to clearly hear system sounds i have to increase the media volume which i have to change as the song/video would be too loud to hear. I'm sorry if this doesn't make sense. I just wanted to check if there's anyway i could have the system volume at full to hear the keypad noise while texting someone and also low to listen to a song at an average level.
  2. Dresa91
    User of the Year 2016; Most Active User 2020 Community Expert Sep 29, 2021
    Dresa91 , Sep 29, 2021 :
    Does this maybe help? https://support.google.com/android/answer/9082609?hl=en
    But Google changed this behavior and merged it since Android Pie (https://android.gadgethacks.com/how...hone-control-media-volume-by-default-0183845/)
    You can submit a suggestion via https://forums.oneplus.com/feedback/
    Maybe OnePlus can add this in future updates
    Caomhin and Artemus like this.
  3. subsidiary
    Froyo Sep 29, 2021
  4. S1636517257933
    Cupcake Nov 19, 2021
    S1636517257933 , Nov 19, 2021 :
    You can turn off your system sounds through your volume button.
    Press the volume button, press the slider icon with 3 sliders at the bottom of the window that pops out, press the settings icon and then scroll down to system sounds, tap on system sounds and turn them off.
