OnePlus 9 pro unknown calls can't block via OnePlus 9 Pro Stellar Black
  1. kishor4all , via OnePlus 9 Pro Stellar Black , Oct 17, 2021 :
    Hello friends,
    As can't block unknown numbers or even when I selected option to block calls from unknown numbers. I'm receiving calls from numbers from whom I don't have saved contact. Is possible to block unknown numbers in OnePlus pro 9? I wanna receive only calls from saved contact anyone can help ?
  2. the_o2
    OnePlus 9 Series Expert Community Expert Oct 17, 2021
    the_o2 , Oct 17, 2021 :
    Hi, open the phone dialer app
    Click on 3 dots on top right corner
    Settings
    Blocked numbers
    Enable the unknown option and see if it works.
    J4t1np4r3kh, Caomhin and G_plusone like this.
  3. G_plusone
    Nougat Oct 17, 2021
    G_plusone , Oct 17, 2021 :
    does it actually work like that!
    the_o2 likes this.
  4. camohan
    Assistant Head Moderator Assistant Head Moderator Oct 17, 2021
    camohan , Oct 17, 2021 :
    Why would someone even want to only receive calls from saved number?
    Imagine you have applied for job, but you can't get the call from recruiter because you don't have the number saved.
    You have a important courier, the courier boy is unable to find your address, he tries calling you but you have blocked the call.
    You forgot something in the cab, the honest cab driver tries to reach your device to inform, but you just walk away.
    ¯\_(ツ)_/¯
  5. the_o2
    the_o2 , via OnePlus 9 Pro , Oct 17, 2021 :
    I tried but it doesn't works like that, it only filters those numbers which are specified as spam call ( not so sure ) like call from network operators etc.
  6. #6
  7. kishor4all , via OnePlus 9 Pro Stellar Black , Oct 17, 2021 :
    Nope it's not working even tried with clear catche and data. Tried calling with my another number it's receiving calls. When true callers helps to block but when we close true calls (turned on background running for battery backup ) so it also stop working.
  8. kishor4all , via OnePlus 9 Pro Stellar Black , Oct 17, 2021 :
    As I'm using two mobile number. Only for bank otp and whatsapp. So I using for spare mostly getting calls from loans and promotion activities so planned to block. main mobile number till in active.
  9. G_plusone
    Nougat Oct 17, 2021
    Ah guessed so.
    Caomhin and the_o2 like this.
  10. the_o2
    We can only give feedback to Google to add this option in their dialer app, nothing else.
  11. Nipu_1998
    The Lab Reviewer - OnePlus Nord 2 Oct 17, 2021
    J4t1np4r3kh, Caomhin and kishor4all like this.
  12. Blue_Monk
    Donut Oct 18, 2021
    Blue_Monk , Oct 18, 2021 :
    If you want you can use do not disturb mode and whitelist the numbers that you want from your phone.
    kishor4all likes this.
