11
Network/Connectivity OnePlus 9 Pro — WiFi Issues
  1. Kermee
    Cupcake Apr 10, 2021
    Kermee , Apr 10, 2021 :
    I have three OnePlus devices in the home. OnePlus 6T, OnePlus 8 Pro and of course, the OnePlus 9 Pro. All connect to a Ubiquiti UniFi nanoHD. The 6T and 8 Pro has never had an issue. But my new 9 Pro's connection will degrade to the point where it's no longer usable until I turn off WiFi, wait 10 seconds, and then turn it back on. There's no fancy settings on the nanoHD but here's the info:
    Device: OnePlus 9 Pro (T-Mobile Version)
    Software: 11.2.2.2.LE5ACB
    Wireless AP: Ubiquiti UniFi nano HD (Firmware: 5.43.35.12698) — Channel 48, 80 MHz
    Anyone else having similar issues? Thanks in advance.
  2. purestock007
    Ice Cream Sandwich Apr 11, 2021
  3. henrik_schack
    Cupcake Apr 11, 2021
    henrik_schack , Apr 11, 2021 :
    I'm having the same issue on a Ubiquiti, I can "force" the error by moving (roaming) from from to the other access point.
    Kermee likes this.
  4. the_o2
    OnePlus 9 Series Expert Community Expert Apr 11, 2021
    Helder_DAlmeida, Caomhin and Kermee like this.
  5. Swejuggalo
    Swejuggalo , via OnePlus 9 Pro Stellar Black , Apr 11, 2021 :
    I've done a few reports on both WiFi and Mobile connectivity in the past. Even if 11.2.3.3 may fix it you might want to report it now too, especially if 11.2.3.3 does not fix hur specific issue.
    When you finally get 11.2.3.3 and if it still does not work a new bug report may be necessary.
    Report can be via the feedback tool built in the Community app.
    In my cases everything has been solved by reporting it. No network issues discovered on 9 series though (yet).
  6. MarkoBatrac
  7. N1619833923773
    Cupcake May 1, 2021
    N1619833923773 , May 1, 2021 :
    I am having the same issue, in my case using TP Link Omada gear, just trying to register my new 9 pro with my companies work profile on Intune took at least 5 attempts and the only way I could get it was by walking outside to ensure I also had mobile signal, normally I leave my device in airplane mode with WiFi and WiFi calling enabled when at home due to low signal, WiFi was and is very spotty, just got the device today
  8. N1619833923773
    Cupcake May 1, 2021
    Just to make sure I’m clear, on just WiFi my registration with Intune kept failing saying network error, had to use mobile network just to get a connection and get it registered which is essentially backwards
  9. Bronkos
    Froyo May 1, 2021
  10. grisuAMS
    Donut May 2, 2021
    grisuAMS , May 2, 2021 :
    Exact same problem.. We have two oneplus 9 pro identical issues with oue Ubiquiti dream machine. We had a three different models still at home, they had no issues at all. Oneplus support recommended a factory reset.. No idea what else we could try?!?
    X1625590158524 likes this.
  11. Bronkos
    Froyo May 4, 2021
    Bronkos , May 4, 2021 :
    Confirm! There is a problem with wifi roaming between the APs. The device will stick too long... even on OOS 11.2.4.4. OnePlus has to fix it.
  12. Jhamende
    Gingerbread May 11, 2021
    Jhamende , May 11, 2021 :
    Exactly the same problem here. Have 2 Unifi AP's On Unifi 6 LR and a Unifi 6 Lite. I have to turn off Wifi and turn it on again. But it happens randomly, it's difficult to take logs ...
    Running Oxygen OS 11.2.5.5.LE15BA on OnePlus 9 Pro.
    Zero issues with my OnePlus 6 a few days ago.
  13. Ghazala.Yasmeen
    OnePlus Bug Hunter Staff Member May 11, 2021
    Ghazala.Yasmeen , May 11, 2021 :
    We are sorry to hear that you are facing the issue with the device and have contacted you through direct message.
    Regards,
    Ghazala
  14. NutZInTheHead
    Cupcake May 14, 2021
    NutZInTheHead , via OnePlus 9 Pro , May 14, 2021 :
    Having the same problem on my oneplus 9 Pro as well.
    I'm on 11.2.5.5 and in the patch notes it says fixes issues with wifi but so far hasn't worked for me. My oneplus 3 and 7 Pro have no such issues so it's definitely a problem with the 9 Pro.
    The problem with mine to be exact is when i left my phone beside my bed idle at night and in the morning opened YouTube app and speed was really bad and things weren't loading fully. Like thumbnails etc. Only after i turned wifi off and back on again that it went back to normal.
    But after a few minutes with screen off and back on again, then same problem all over again.
  15. ilcorvaccio
    ilcorvaccio , May 14, 2021 :
    I have the exact same issue:
    I configured my Unifi Dream Machine with two U6-Lite access points, first they were running both 2.4 and 5 ghz bands one one SSID and I thought that was the issue, then I separated them by allocating a new SSID for the 5 Ghz band.
    Nothing solved the issue, my phone still randomly and very often struggle to connect to internet, it's 100% of the time connected to a wifi network but shows the "no internet" exclamation mark.
    It's very annoying as I rely on my phone notifications for work as well so I have to turn wireless off to get it work when I'm waiting for important emails/messages.
    At first I thought it was my new unifi APs the issue but no one in my family has the same issues, I have plenty of devices connected to my wifi network and they just work fine.
    I can't believe a device that costed me £900+ is having those annoying bugs
    device: Oneplus 9 PRO 256 GB, Oxygen OS 11.2.5.5.LE15BA updated yesterday 13.06.2021
  16. K1616514190223
    K1616514190223 , May 14, 2021 :
    I can confirm.
    Just replaced my OP7 with OP9 and since then we (wife have the same phone) have major issues with wifi saying there's no internet, then it randomly comes back.
    All other devices in the network have no issues at all, only the OP9s.
    Running Unifis latest APs with WIFI 6.
    I work in IT (sysadmin) and tried everything to debug, still same issue...
    Where can I report bugs regarding this?
    Jacq likes this.
  17. ilcorvaccio
    Cupcake May 18, 2021
    ilcorvaccio , May 18, 2021 :
    Seems like I found a temporary solution until oneplus release a patch (will it?) and it's simple: static IP
    1. set a static ip to your Oneplus device from Unifi UI
    2. Assign same ip on the oneplus Wireless network settings
    3. Disable Intelligent Select the best wifi feature
    Made the change yesterday and no the roaming issue since then.
    ps. I'm not sure but probably step 2 is not required as router will force assign a static IP once you enforce it from Unifi UI
  18. Jacq
    Donut May 18, 2021
    Jacq , May 18, 2021 :
    Wifi is super slow when not 5 meters from the router.
    I have OP6 and OP9 Pro (11.2.5.5.LE15BA), old one works just fine, (to compare 13,5mbps ping 2ms vs 1,4mbps ping 29ms sic!)
    OnePlus c'mon pretty basic stuff not working and it's been few updates already....
  19. I1616513421780
    I1616513421780 , May 18, 2021 :
    Same issue here. Unifi wifi 6, only thing that worked for me was making a 2.4 only network and putting my one plus on that. Just seems to not like unifi and 5ghz.
  20. sfwildt
    sfwildt , May 18, 2021 :
    Same here as well and already reported a while ago with the support tool.
