135
OnePlus 9 Series FAQs, answered by OnePlus staff
  1. RAJ1307
    Cupcake Dec 23, 2021
  2. S1634545757397
    Cupcake Dec 24, 2021
    S1634545757397 , via OnePlus 9 , Dec 24, 2021 :
    I'm not able to use OnePlus 9 hotspot on laptop it doesn't show any sign of connection available for my laptop.. kindly help me how to use its connection with laptop
  3. suraj019
    Eclair Dec 25, 2021
    suraj019 , via OnePlus 9R , Dec 25, 2021 :
    Oneplus 9 has snapdragon 888 which usually heats up , which indeed causes battery drain
  4. RAJ1307
    Cupcake Dec 25, 2021
    RAJ1307 , via OnePlus 9 , Dec 25, 2021 :
    But with in 4-5 hours it goes to 0 from 100
  5. agarwal.puru17
    agarwal.puru17 , via OnePlus 9R , Dec 25, 2021 :
    Hi. Can anyone tell how to fix this issue. Every morning when i use my 9R, the touch becomes unresponsive and crashes. Basically it does not take my touch input. To fix this issue I have to restart my device by long pressing the power key and clicking on restart button on the top. But I have been facing this problem on a daily basis for the last 2-3 months.
    Any help would be appreciated.
    Also I have done the factory reset, but I am still facing the same issue!
  6. Vinay4670
    Vinay4670 , via OnePlus 9R , Dec 25, 2021 :
    Not sure when the issue related to WiFi calling would be fixed..call doesn't connect and gets disconnected many times..I had to turn on and turn off airplane mode when iam on wifi calling then it used to work...so I have just stopped using wifi calling..
  7. the_o2
    OnePlus 9 Series Expert Community Expert Dec 25, 2021
    the_o2 , Dec 25, 2021 :
    Is it happening after the alarm clock?
  8. agarwal.puru17
    Yeah I also thought of it at first, but then I put an alarm for +5 minutes when i was checking it someday, but there was no issue as such. It generally happens when mobile is kept idle for sometime.
    Note : I have read a possible solution today, in one of the forums, they told to disable bubble notification. Lets see tomorrow if this happens again!
    the_o2 likes this.
  9. the_o2
    If it still happens, disable the clock app too and use the Google Clock available on Play Store and see.
    agarwal.puru17 likes this.
  10. agarwal.puru17
    I hope all these issues would get fixed in Android 12 update. Also, it's sad to see 9R lagging behind in getting Android 12 update, considering 9 & 9 pro have already got the OTA update
  11. pvilarinho74
    Ice Cream Sandwich Dec 25, 2021
    pvilarinho74 , via OnePlus 9 Winter Mist , Dec 25, 2021 :
    I have the OnePlus dialer installed instead of Google's...like someone said before, Google is your friend.
  12. pvilarinho74
    As far as I know the R model does not support wireless charging...but hey, might be wrong.
  13. P1627737017609
    Cupcake Dec 26, 2021
  14. S1623308860110
    Cupcake Jan 3, 2022
    S1623308860110 , via OnePlus 9 , Jan 3, 2022 :
    I'm facing trouble with my camera of OnePlus 9, the photos get blurry and this has been happening a lot lately after the latest update. Would be great if anyone could help me out with it.
  15. F1595133077766
    Cupcake Jan 4, 2022
  16. U1638542044084
    Cupcake Jan 5, 2022
  17. F1642132482463
    Cupcake Jan 14, 2022
  18. the_o2
    OnePlus 9 Series Expert Community Expert Jan 14, 2022
    the_o2 , Jan 14, 2022 :
    What search engine?
  19. F1642132482463
  20. MohamedBelal
    MohamedBelal , via OnePlus 9 , Jan 14, 2022 :
    I have 9 LE2115 and can not charge it wirelessly even I have the option in settings
