16
OnePlus 9 shelf
  1. P1624258881832
    Cupcake Jun 23, 2021
    P1624258881832 , Jun 23, 2021 :
    This is a very common scenario that we want to see notification area when we swipe down. The shelf should be accessible when we swipe right as it was on older phones.
  2. Backdraft83
    Cupcake Jul 26, 2021
    Backdraft83 , Jul 26, 2021 :
    I'd be happy with just an icon that would launch the shelf.
    I'm wondering why nobody has done this. Should be an easy "hack" for some developer.
  3. 289srikant
    Donut Jul 28, 2021
    289srikant , via OnePlus 9 , Jul 28, 2021 :
    Solution for the problem :
    Go to Home settings
    There you will find "swipe down to access" option
    Choose what u want there
    PROBLEM SOLVED !!! 😊😊😊
  4. oriusnex
    Donut Sep 24, 2021
    oriusnex , via OnePlus 9 Pro , Sep 24, 2021 :
    I too went from op5t to op9p and I really miss the -1 shelf. The Google alternative is awful, and pull down needs to be tied to the drawer for comfort. Please give us the option back, OnePlus!
    razvangvr likes this.
  5. razvangvr
    Cupcake Nov 14, 2021
    razvangvr , Nov 14, 2021 :
    I moved from OP7T to OP9 , and I miss this feature. I want to access to self with Swipe Right. Please bring it back!
    oriusnex likes this.
  6. Herge2000
    Cupcake Dec 2, 2021
    Herge2000 , Dec 2, 2021 :
    Unfortunately not solved, cause many people want the shelf on left side (slide to the right).
  7. Leiya
    Cupcake Dec 3, 2021
    Leiya , Dec 3, 2021 :
    I want to use it desperately, but I cannot activate it anymore in 9Pro. Anyone who knows how this works?
  8. Aaron2017
    General Support Expert Award 2021 Dec 3, 2021
    Aaron2017 , Dec 3, 2021 :
    Long press on an empty space on the home screen>home settings>swipe down to access and set that to shelf
    Bobbie63 and Leiya like this.
  9. Leiya
    Cupcake Dec 3, 2021
    Leiya , via OnePlus 9 Pro , Dec 3, 2021 :
    Thank you for helping me. Except that this didn't work. It made my apps tiny, so that I can rearrange apps in different home-screens. I want to turn on the Shelf menu. I already programmed my home-burton to open the Shelf menu. When I do that, it says: first activate Shelf (in Dutch). But I really do not know how. Do you?
    Aaron2017 likes this.
  10. Aaron2017
    I think you mistakenly enabled "alleen startscherm" in the "launcherindeling" instelling. I'll write it again in Dutch:
    Op een lege plek op het startscherm drukken>instellingen startscherm>veeg omlaag om te openen>shelf aanduiden in plaats van meldingen en snelle instellingen
    Leiya and Bobbie63 like this.
  11. Leiya
    Cupcake Dec 3, 2021
    YESS! Je bent een held! Hartstikke bedankt. Het is gelukt eindelijk.
    Nooit gezien en geweten dat het startscherm ook nog een eigen instellingenwieltje heeft.
    Je ziet: je hebt me heel blij gemaakt, Aaron, thanks!
  12. Aaron2017
    Zo leren we allemaal wel iets bij.😉 Blij dat te horen, graag gedaan.👍
    Leiya likes this.
  13. milosusa
    Cupcake Dec 4, 2021
    milosusa , Dec 4, 2021 :
    Yes they should brink this back.
  14. thomas.vonau
    Cupcake Jan 11, 2022
    thomas.vonau , via OnePlus 9 , Jan 11, 2022 :
    Here is my tips for mitigating the disparition of the shelf on OnePlus 9 (I had a OnePlus 6T before): open your "button and gesture" section, choose the "back, home, recents" navigation bar, customize your navigation gestures by for instance opening the shelf when double taping on the back button
  15. ilkromp
    Cupcake Jan 23, 2022
    ilkromp , Jan 23, 2022 :
  16. ilkromp
  17. ilkromp
    Hi People,
    You can access the shelf also lower from the screen. Try anywhere where is an empty spot without an icon..
  18. Boncio
    Cupcake Mar 22, 2022
    Boncio , Mar 22, 2022 :
    I have a problem, after upgrade to OS12, the swipe to open the shelf doesn't work, it means that my shelf is unusuable. Someone can help me
    #38
  19. Aaron2017
    General Support Expert Award 2021 Mar 22, 2022
    Aaron2017 , Mar 22, 2022 :
    Did you try swiping down from the top right corner? That's the only way to access shelf, if it's enabled in settings first
    #39
  20. Boncio
    Boncio , via OnePlus 9 , Mar 22, 2022 :
    I tryed everywhere in the screen expecially in the top right corner. It doesn't work and it is activated in the settings
    #40
