Oneplus 9 side panel paint peeling side panel quality wad very very poor via OnePlus 9
  1. V.C.SATHISH
    Cupcake Aug 1, 2021
    V.C.SATHISH , via OnePlus 9 , Aug 1, 2021 :
    From oneplus 9 purchased one month before and now the side panel frame was plastic so paint eas peeling within 1 month pls improve quality or help me about that or otherwise i need the price of side panel frame
  2. pablofg1978
    Head Moderator Head Moderator Aug 1, 2021
    pablofg1978 , Aug 1, 2021 :
    Can you share some pictures?
    Contact support or visit a service center for a propper quote
    Dresa91 and Caomhin like this.
  3. HarshKK14
    Honeycomb Aug 1, 2021
    HarshKK14 , via OnePlus 7 , Aug 1, 2021 :
    Lol, had the same issue with OnePlus Nord. The paint does peel off even with cover 😕.
    OnePlus won't return any money nor will they replace anything. Reason: Normal wear and tear.
  4. V.C.SATHISH
    Cupcake Aug 1, 2021
  5. DileepMuvvala
    Gingerbread Aug 1, 2021
  6. Gamingtime1121
    Tokolozi, McJader and Caomhin like this.
  7. V.C.SATHISH
    Cupcake Aug 1, 2021
  8. Aaron2017
    Lollipop Aug 1, 2021
    Aaron2017 , via OnePlus 8 Pro , Aug 1, 2021 :
    Either visit the service center or contact support via the various ways possible on their website if you wish to get it fixed or put a case around it and let it be if you can live with it.
  9. mahie99
    Eclair Aug 2, 2021
  10. V.C.SATHISH
    Cupcake Aug 3, 2021
    V.C.SATHISH , via OnePlus 9 , Aug 3, 2021 :
    Bro i am using soft case also then itself peeling out and am normally every 6 months changing mobiles so if i put exchange then value will be very lower
  11. #11
  12. Aaron2017
    Lollipop Aug 4, 2021
    Aaron2017 , Aug 4, 2021 :
    How does restarting a phone fix paint coming off from the sides?🤔
    Does!Compute and Dresa91 like this.
  13. Dresa91
    User of the Year 2016; Most Active User 2020 Aug 4, 2021
    Dresa91 , Aug 4, 2021 :
  14. mahie99
    Eclair Aug 4, 2021
    Dresa91 likes this.
  15. Gamingtime1121
    Honeycomb Aug 4, 2021
    McJader and Dresa91 like this.
