Working Oneplus 9 Usb Driver not working via OnePlus 9 Arctic Sky
  1. shuvarup1995 , via OnePlus 9 Arctic Sky , May 12, 2021 :
    Whenever i am pluging my oneplus 9 phone throught type C to C cable directly to my HP Omen laptop (which has a dedicated usb C 3.1 port) it gives a popup at right side corner bt it also disappears within 1sec.
    What to do? Cant access my device folders on the laptop. 😔
    Please help.
    M1628703013440 likes this.
  2. Gav_W86
    Moderator Moderator May 13, 2021
    Gav_W86 , May 13, 2021 :
    what does the pop up say?
    when you connect is there a notification on the phone that you can tap to change between connection modes?
  3. shuvarup1995 , via OnePlus 9 Arctic Sky , May 13, 2021 :
    Yes its there on the phone but not nothing appears on the computer.
  4. Gav_W86
    ok, Windows, Linux or MacOS? what does the pop up on the laptop say?
  5. shuvarup1995 , via OnePlus 9 Arctic Sky , May 13, 2021 :
    Windows 10. Like the popup recognise the device as soon as i connect it but it disappears the very moment. Again after few moments it repeats.
  6. Gav_W86
    so does the popup say its detected a OnePlus device, or an unknown device?
  7. #7
  8. Gav_W86
    Moderator Moderator May 14, 2021
    shuvarup1995 likes this.
  9. #9
  10. M1628703013440
    Donut Oct 18, 2021
    M1628703013440 , Oct 18, 2021 :
    I have the same problem as well.
    Even after installing the driver the pc recognizes and then removes it just like before.
    The pc tries to recognize the phone again after 30 seconds and so on...
    the notification on the pc only comes for less then a second so it is hard to capture it and I have checked the device manager as well, windows basically removes it from the connected devices
  11. M1628703013440
    Donut Oct 18, 2021
    the popup looks as in the attached file
    and no notification on the phone that you can tap to change between connection modes
      File size:
      451.8 KB
  12. M1628703013440
    Donut Oct 18, 2021
    Even the wireless debugging feature in android 11 is not working with one plus 9 pro, 😔.
    " No connection could be made because the target machine actively refused it. (10061) "
  13. Gav_W86
    Moderator Moderator Oct 18, 2021
    Gav_W86 , Oct 18, 2021 :
    so what happens if you tap that notification?
  14. M1628703013440
    Donut Oct 18, 2021
    Nothing happens...
    As I said the usb is detected by the pc for a split second only and after that it is not even in the device manager so it isn't even possible to click that notification and even if it is, it does not do anything.
    I tried every fix I could find , even scraped the microsoft docs and none of the solutions work
    I can't even use the usb and the wireless debugging feature to develope an android app. That is what every other less flagship phones could. So please fix it as soon as you can.
  15. Gav_W86
    Moderator Moderator Oct 19, 2021
    Gav_W86 , Oct 19, 2021 :
    given that it works for others I check with (and on every device I've tried) it would be unlikely to be an OS issue.
    have you tried it on a different pc?
  16. shuvarup1995 , via OnePlus 9 Arctic Sky , Oct 20, 2021 :
    Please check on a laptop with oneplus 9 or 9 pro with the help of type c to c cable then we wil see the same.
  17. Gav_W86
    Moderator Moderator Oct 20, 2021
    Gav_W86 , Oct 20, 2021 :
    9 pro works on my Mac and Razer Windows laptop
  18. #18
  19. Gav_W86
    yes
  20. #20
