oneplus 9r 5g problem
  1. F_Tasos_Paras_thgI
    Cupcake Jul 28, 2021
    F_Tasos_Paras_thgI , Jul 28, 2021 :
    i try to use it at Vodafone network in Greece but not working.
    Is it any solution for this problem?
    Thanks in advance
  2. pkg3107
    Ice Cream Sandwich Jul 28, 2021
    pkg3107 , Jul 28, 2021 :
    Check the compatibility of Vodafone SIM with the Nord Bands. If the bands supported by Vodafone has the ones available in your model, the SIM should work.
    Caomhin likes this.
  3. F_Tasos_Paras_thgI
    Cupcake Jul 30, 2021
    F_Tasos_Paras_thgI , Jul 30, 2021 :
    Where can i find the bands of Nord?
  4. pkg3107
    Ice Cream Sandwich Jul 30, 2021
    pkg3107 , Jul 30, 2021 :
    Go to the OnePlus Website-- Product Page-- Carrier compatibility
    It will show the compatibility of various service providers and their supported bandwidth.
    Which country are you in?
  5. F_Tasos_Paras_thgI
    I'm at Greece and my network is Vodafone Greece
  6. pkg3107
    Which device do you have? 9 or 9 Pro?
    Edit: I checked online. Greece doesn't support 5G on Vodafone SIM.
    The snap shows n/a (not available) for all the Networks.
  7. F_Tasos_Paras_thgI
  8. F_Tasos_Paras_thgI
  9. F_Tasos_Paras_thgI
  10. #10
