OnePlus 9R battery draining via OnePlus 9R
  1. Gaurav1766
    Cupcake May 7, 2021
    Gaurav1766 , via OnePlus 9R , May 7, 2021 :
    Hello all,
    It's been just 6 days and I have already started facing severe battery draining issues on OnePlus 9R
    Although the phone has massive 4500 mah battery it really doesn't feel like it.
    Just by using phone for normal usage like Social media,it merely lasts for 4-5 hrs.
    This is really not acceptable from a so called flagship phone of OnePlus.
    In addition to it, while charging the device it heats up to 45 degree and more. Also heating issue stays while normal usage.
    OnePlus team please look into the issue at the earliest!!
  2. Artemus
    Community Hero 2020 May 7, 2021
    Artemus , May 7, 2021 :
    No team here, just users like you. For starters, please take and attach a screenshot of your battery graph (Settings > Battery > View detailed usage) as well as a screenshot from an app called CPU-Z's thermal tab which tells you how warm the phone is. Charging while using the phone will result in excess heat being generated and is normal.
    Caoimhín likes this.
  3. karanmalviya
    Froyo May 7, 2021
  4. F_Anurag_Singh_Jadon_
    Cupcake May 9, 2021
  5. karanmalviya
    Froyo May 9, 2021
    karanmalviya , via OnePlus 9R , May 9, 2021 :
    All depends on usage and network. Don't worry 6hrs is good. Even I saw few screenshots of close to 10hrs of sot.
    F_Anurag_Singh_Jadon_ likes this.
