Oneplus 9r wifi problem via OnePlus 7
  1. ija89
    Froyo Jun 29, 2021
    ija89 , via OnePlus 7 , Jun 29, 2021 :
    I got my oneplus 9r yesterday. When i do startup configuration im not able to see any 5Ghz wifi signal. After first setup complete i try to connect my oneplus 9r with 5ghz wifi but same its not visible. I try reset network setting and i reset the mobile also but still 5ghz wifi signal is visible in mobile.
    Is there any one facing same issue or im the only one facing this issue?
    Is there any fix or option to enable 5ghz wifi signal?
    Please suggest me friends
    Raj_Kanabar08 likes this.
  2. Swejuggalo
    OnePlus 9 Series Expert Community Expert Jun 29, 2021
    Caomhin likes this.
  3. ija89
    Froyo Jun 30, 2021
    ija89 , via OnePlus 7 , Jun 30, 2021 :
    Im having oneplus 7 in that phone im able to access the 5ghz wifi signal. Only problem in oneplus 9r.
    I try to add 5ghz wifi signal in oneplus 9r using the Qr code but its not connecting
  4. Swejuggalo
    OnePlus 9 Series Expert Community Expert Jun 30, 2021
    ija89 and Caomhin like this.
  5. ija89
    Froyo Jul 1, 2021
  6. Swejuggalo
    OnePlus 9 Series Expert Community Expert Jul 2, 2021
    Swejuggalo , via OnePlus 9 Pro Stellar Black , Jul 2, 2021 :
    Could for example be a encryption level conflict somehow. The short moment it is connected does it work properly?
    Single SSID? What WPA setting on the router?
    There have been various types of fixes for people.
    Split the 2.4 and 5 GHz in 2 SSID, change to a better channel manually (depending on surrounding networks), use a different encryption (WPA3 of available), upgrade router firmware, disable WiFi 6. Depends on what router you have.
    It could be a modem conflict with your router or the other way around. The router having issues with certain types of clients.
  7. W1624997724289
    Cupcake Jul 5, 2021
  8. akshaynow
    Donut Jul 10, 2021
    akshaynow , via OnePlus 9R , Jul 10, 2021 :
    I have before this same problem, go to wifi router settings and go to 5Ghz settings change channel from auto to 44 and restart router , your OnePlus phone will start showing 5ghz.
  9. N1633273011011
    Cupcake Oct 11, 2021
    N1633273011011 , Oct 11, 2021 :
    [QUOTE = "akshaynow, post: 23423901, member: 4624168"] Tôi cũng gặp phải vấn đề tương tự trước đây, hãy chuyển đến cài đặt bộ định tuyến wifi và chuyển đến cài đặt 5Ghz, thay đổi kênh từ tự động thành 44 và khởi động lại bộ định tuyến, điện thoại OnePlus của bạn sẽ bắt đầu hiển thị 5ghz. [/TRÍCH DẪN]
    bạn có thể hướng dẫn tôi không?
  10. TommysZ
    Cupcake Oct 24, 2021
    TommysZ , via OnePlus 9R , Oct 24, 2021 :
    this is working. Thank you
    akshaynow likes this.
  11. mohithkannan23
    Cupcake Nov 15, 2021
    mohithkannan23 , via OnePlus 9R , Nov 15, 2021 :
    Is this works only for oneplus devices?
  12. Swejuggalo
    OnePlus 9 Series Expert Community Expert Nov 15, 2021
  13. mohithkannan23
    Can u help me through this wifi problem
    My mobile name is oppo f11 pro it supports 5ghz but it's not showing there why?
  14. Swejuggalo
    Swejuggalo , via OnePlus 9 Pro Morning Mist , Nov 15, 2021 :
    Try changing to different channel in router. What channel to use can depend on your neighbours.
    But the channel must be within range of what the phone modem supports or the WiFi won't show up.
