oneplus band is not turning on after battery drain
  1. jithuchandran
    Donut Apr 4, 2021
    jithuchandran , Apr 4, 2021 :
    My oneplus band is not turning on after battery drain. I tried it chargin multiple ways (wall adapter, power bank, laptop usb slot etc.). Is there anything specifically need to be done if it is turned off after battery drain?
    dirspective likes this.
  2. dirspective
    Cupcake Apr 26, 2021
  3. dirspective
    Cupcake Apr 27, 2021
  4. raghuvirsingh95
    Cupcake May 12, 2021
  5. sha2nk99
    Cupcake May 13, 2021
  6. I1606663260782
    Cupcake May 15, 2021
  7. D1601836005938
    Cupcake May 17, 2021
  8. scurvydude5
    scurvydude5 , May 17, 2021 :
    Same problem. No support available.
  9. M1596193709379
    Cupcake May 24, 2021
    M1596193709379 , via OnePlus 5T , May 24, 2021 :
    Yes the battery is draining a lot if I on the spo2 while sleeping so we buyed it only because it will do all the work and it is say it will take more battery if you on the spo2 so please give update fast for the band
  10. D1601836005938
    Cupcake Jun 9, 2021
  11. U1601218976722
    Cupcake Jun 10, 2021
