260
Accessories OnePlus Buds: An Honest Review
Which color is your favorite?
Poll closed Oct 7, 2020.
  1. White
    10.1%
  2. Nord Blue
    22.9%
  3. Gray
    30.3%
  4. Please launch Matte Black
    36.7%
  1. swaroopbhat
    Froyo Sep 26, 2020
  2. swaroopbhat
    Froyo Sep 26, 2020
    swaroopbhat , via OnePlus 7 , Sep 26, 2020 :
    Then it should give a notification regarding .309 update of the buds while connected
  3. Pratyaksh Rao
    Cupcake Sep 26, 2020
    Pratyaksh Rao , via OnePlus 8 Pro , Sep 26, 2020 :
    initially when i first connected the buds the firmware was 327. something and then it got updated to 340.309 but there was no notification regarding it
    i had to restart my phone to see the updated version in settings.
  4. rahuladreamm
    Donut Sep 26, 2020
    rahuladreamm , Sep 26, 2020 :
    What I have debug so far that this is Software issue not hardware issue.
    Your both bud is fine just an software bug due to this Issue is keeps happening.
    Like now mine working fine since 2 days.
    See.
    What I have done so far.
    1. I have left both buds outside and let them be dead.
    2. Charge using case and let the case be dead.
    3. Reset the buds and don't connect OP phone.
    4. Connect some other phone.
    5. Reset it again.
    6. Now connect to OP
    Seems stupid idea like bud but works for me.
    Give a try.
  5. rahuladreamm
    Donut Sep 26, 2020
    This is not honest review
    don't fall for it.
    Get the fact right.
    Bud is not their industry so they make lots of unknowing mistake.
    So don't just buy check before buying it.
    The above screenshot buds purchased after 15 days just like what happen to Chinese earphones the left one is dead and even customer support don't What to do.
    There answer it will be fixed in next update.
    What a stupid and waste product.
  6. Pratyaksh Rao
    thanks brother, I'll give it a try
  7. Pratyaksh Rao
    by leaving them outside you mean drain their battery ?
    rahuladreamm likes this.
  8. Thorodon
    Eclair Sep 28, 2020
  9. rahuladreamm
    Donut Sep 28, 2020
    rahuladreamm , Sep 28, 2020 :
    correct
  10. luigimario
    The Lab - OnePlus 6T Reviewer Oct 2, 2020
    luigimario , Oct 2, 2020 :
    Hey Bats, I actually read your whole review! Good stuff! As for new gestures, I have been looking at Mpow TWS buds on Amazon and they have about 9 functions I think. It is really well designed and I don't see why OnePlus couldn't use the same functions. They are all tap or hold commands so no need for swiping because I think that would be less reliable. I just got a pair of the buds (in white sadly) and I was surprised they even stayed in my ears (don't feel secure). My ears are not a good shape for earbuds overall but the OP buds are nice for sure.
    Do you know who I would contact to give the gesture control suggestion to? I don't remember who was the Buds project manager.
    Batman360 likes this.
  11. Batman360
    OnePlus Accessory Tester Oct 2, 2020
    Batman360 , Oct 2, 2020 :
    Glad to liked the review 😊
    And yes, you are correct there are just tap and hold gestures, hence less of them. And the Buds are really ear specific tbh, some say it fits well, some say ot doesn't. So kinda personal preference.
    Christine L. is the product manager for Buds, you can contact her though 😊
    luigimario likes this.
  12. luigimario
    Thanks, I'll DM her my suggestion. I think it would be a really easy software update and it would make these buds worth the price. It's $110 in Canada and the Mpow buds are half that price or lower with more features and silicone tips. May not have as good sound but better value for sure. If these buds had as many functions (especially controlling volume) I think I could justify the price.
  13. Batman360
    I know man, I soo crave for volume control on these🥺🥺
  14. luigimario
    Yeah, check the controls on these. Really versatile! 30% less than OP Buds and have (limited) ANC.
    https://www.amazon.ca/Mpow-X3-Bluetooth-Cancellation-Waterproof/dp/B082G2RKSV?th=1
    Get Access to Multiple Function
    Volume: Tap side of earphones once left to decrease, right to increase
    1 Next track: triple-touch the MFB of R-earbud
    2. Previous track: triple-touch the MFB of L-earbud.
    3. Play or pause: double touch the MFB of either earbud.
    4. Answer a call: touch the MFB of either earbud once.
    5. End a call: double touch the MFB of either earbud.
    5. Reject a call: press and hold the MFB button of either earbud for 2 seconds.
    6. Activate Siri or Google Assistant: press and hold the MFB of L-earbud for 2 seconds when in twin mode; press and hold the MFB of R-earbud for 2 seconds when in right mono mode.
    7. Turn on or off ANC: press and hold the R-earbud for 2 seconds when in twin mode. The mono(right) mode does not support ANC.
    8. Reset: 1) turn off your phone's or other Bluetooth-enabled device's Bluetooth;2) take out the R-eabud from the charging case; 3) press and hold the R-earbud for 10 seconds. The red LED light will flash 3 times, which means that the paired information is cleared successfully.
    R1601268782063 and Batman360 like this.
  15. Batman360
    These look soo good on papers🔥🔥
    R1601268782063 and luigimario like this.
  16. luigimario
    Yeah, I was going to wait for prime day in a couple weeks to buy it but I won some OP buds so I'm good. Not gonna spend money if I don't need to. Never been big on headphones anyway.
    The X3 doesn't have BT 5.0 or aptx. So not sure how great they are in the end.
  17. swaroopbhat
    Froyo Oct 4, 2020
    swaroopbhat , via OnePlus 7 , Oct 4, 2020 :
    Looking at the recent specs of the OnePlus buds Z, is it going to actually be cheaper than the OnePlus buds? It has IP55, silicone tips, lighter in weight, has airpods like design and definitely going to have better touch controls.. Will it be cheaper?
    ashish77363 likes this.
