OnePlus Buds cause ear skin infaction due to bad quality of material. via OnePlus 7 Pro
  1. BourneJSN
    Cupcake Sep 21, 2020
    BourneJSN , via OnePlus 7 Pro , Sep 21, 2020 :
    I contacted OnePlus support through Email and twitter, No response yet. I bought OnePlus buds for ₹4999 and paid ₹6000 for treatment of ear infaction due to OnePlus Buds. I got the medical certificate for the same also. OnePlus used bad quality material for cost cutting and now no customer support. Would I buy any OnePlus product after this in future?
  2. Starcommander
    OnePlus Accessory Tester Sep 21, 2020
    Starcommander , Sep 21, 2020 :
    This is worrying me..
  3. Bobbie63
    Marshmallow Sep 21, 2020
  4. Starcommander
    From last 1 week my ears are itching and hurting while using left buds...
    Also, my ears had a cut, because of improper finishing on lower side of bud.
    Bobbie63 likes this.
  5. Godfather 1
    Jelly Bean Sep 21, 2020
    Godfather 1 , Sep 21, 2020 :
    Is this really happening?
  6. Bobbie63
    Bobbie63 , Sep 21, 2020 :
    Ok, haven’t seen too many people complaining about that tbh, then again, didn't read much on ear buts tbh. I'd say normally the materials used are certified I presume. In which case it would be difficult to just pin point the material as being the cause. Using ear buts can enhance certain conditions, that's for sure. Also a certain care should take place like regular cleaning them not wearing them for too long and stuff like that.
    Ear buts is like closing up an space that's normally open. It's like a Petri dish with a lid on it
    Starcommander likes this.
  7. Starcommander
    Yeah true. Material is not the issue. But the rough surface in the bottom of earbud near the stem might cause issue.
  8. Bobbie63
    That could well be, forgot to mention that. These things just should happen and should be avoided by design or QA.
    Edit
    Were it burs from the moulds?
  9. VishnuArvind
    Cupcake Sep 23, 2020
    VishnuArvind , Sep 23, 2020 :
    Yes definitely there is some surface finish issues with the buds, for me it hurts the upper part of the ear at the end of the top speaker, the speaker cut's end is coinciding with the inner-top ear bone and hurts a lot, I am not willing to apply for RMA as I read some issues with the customer service not responding and, also tried my self contacting them through the website earlier this week and waited for nearly 20 minutes but no response, even though it is possible to apply for RMA i am not sure, I think the replacement will also have the same flaw because its a design issue, is this just my ear or someone else having this problems let me know if you have any.
    edit : i am having a gray version, i am not getting any infections, the top speaker notch just hurts the skin.
  10. Godfather 1
    Jelly Bean Sep 23, 2020
    Godfather 1 , Sep 23, 2020 :
    If it hurts a lot.. don't you think you should return it?
  11. BourneJSN
    Cupcake Sep 27, 2020
  12. BourneJSN
    BourneJSN , via OnePlus 7 Pro , Sep 27, 2020 :
    It's material issue or finishing issue, but these buds are not usable after spending ₹4999. And No option to return it. Because service center can replace the product if there is problem in the product. Service center is not even considering the issue I'm facing right now.
  13. dsmonteiro
    Community Consultant Staff Member Sep 27, 2020
    dsmonteiro , Sep 27, 2020 :
    Hi there, my name is David and I'm part of the Community team. Can you please send me a private message with the medical certificate you mentioned in the initial post so I can forward this internally?
    pablofg1978 likes this.
  14. BourneJSN
    Send me your official email, I'll share with you formally.
  15. dsmonteiro
    I just sent you a message with my email address.
  16. BourneJSN
