2
OnePlus buds pro beeping when I place the buds in case
  1. Darwin94
    Gingerbread Jan 23, 2022
    Darwin94 , via OnePlus 9 Pro , Jan 23, 2022 :
    Yes, it has dual connection. Maybe is some hardware bug or something.
  2. Z1634068566873
    Cupcake Jan 23, 2022
    Z1634068566873 , Jan 23, 2022 :
    Guys I asked OnePlus support and they said that's not a bug and it's completely normal and nothing to worry about
  3. Darwin94
    I contacted support and they told me that it should be replaced and is not a normal behavior, it could harm the buds in a long term.
  4. Z1634068566873
    Darwin94 likes this.
  5. Z1634068566873
    Cupcake Jan 24, 2022
    Z1634068566873 , Jan 24, 2022 :
    I noticed also that it doesn't do that if I waited for the green indicator to turn off before I close the case
  6. Toyguy22
    Honeycomb Jan 24, 2022
    Toyguy22 , Jan 24, 2022 :
    I believe this is completely normal and nothing to worry about.
    I encountered my Buds Pro doing a beep when I put them back in the case today. I think this is an audio warning, indicating that your charging case is either low on battery or completely empty of charge and/or the Buds Pro themselves are low on charge. Both my charging case was drained and my Buds Pro themselves were almost dead too so not exactly sure which criteria need to fit for the beep to happen. I'm pretty sure I've had my Buds Pro low on charge before but don't recall hearing a beep when I put them back in so maybe it needs to be both the case and the buds are almost drained where it will do the beep. Anyways, once I fully charged my case (with the Buds Pro inside at the same time), it no longer did the beep after taking them out, using them, and then putting them back in.
    Darwin94 and Z1634068566873 like this.
  7. albertthomas1998
    Cupcake Mar 30, 2022
    albertthomas1998 , Mar 30, 2022 :
    I too have the same issue when i place my one earbud place inside case when its battery is at 10%. Is there any solution for this?
