Oneplus Buds Pro case issue(?)
  1. verebespeti
    Cupcake Sep 19, 2021
    verebespeti , Sep 19, 2021 :
    Hello guys! I just got the new OnePlus Buds Pro earbuds 2 days ago. I have a small issue with it, and I don't know if its worth a replace or it's a common issue. So the issue is with the case's closing. It's opening very easily, like there's no magnet at all, and has a cheap plastic sound when I open it. When I close the case, the green light is flashing two times right after the close sound, which means it's basically opened. It's normal that the case opens without applying 0 pressure? I had earbuds before and all of them needed a really small amount of force to open because there was a magnet in the case.
  2. Shailender Sharma
    Nougat Sep 20, 2021
    Shailender Sharma , Sep 20, 2021 :
    Share your experience @Starcommander @Venky61 should the user go for replacement of the buds pro?
    Contact OnePlus support Here
    Starcommander likes this.
  3. Starcommander
    OnePlus Accessory Tester Sep 20, 2021
    Starcommander , Sep 20, 2021 :
    Go to service centre and get it replaced. Few of my friends had this issue. In my case the binge became loose but magnets didn't gave up yet.
    Liehjan and Shailender Sharma like this.
  4. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Sep 21, 2021
    Liehjan , Sep 21, 2021 :
    Replace them. Mine doesn't have this issue.
