3
OnePlus Buds Pro not showing settings to control ANC via OnePlus 7T Glacier Blue
  1. #2
    Sandeep Joginipelly likes this.
  2. Dresa91
    User of the Year 2016; Most Active User 2020 Aug 27, 2021
  3. prajvalshetty , via OnePlus 7T Glacier Blue , Aug 27, 2021 :
    Tried to download from apk mirror but it says it's only for android 11. I'm currently on android 10 on my Oneplus 7T as OOS 11 update is not stable update for 7T devices
  4. Dresa91
    Dresa91 , Aug 27, 2021 :
    Then you have to wait.
    Those new features were being released with the latest OnePlus Buds App version
  5. P1562830529074
    Cupcake Aug 27, 2021
  6. P1562830529074
  7. Dresa91
  8. ChrisSaji
    Cupcake Aug 28, 2021
  9. saif1233
    Cupcake Aug 29, 2021
    saif1233 , Aug 29, 2021 :
    Using OP6 and facing the same issue, I will try the above method to see if it works..
  10. S1541910109130
    Cupcake Sep 6, 2021
  11. S1541910109130
    Cupcake Sep 6, 2021
  12. #13
  13. G_An
    Cupcake Sep 10, 2021
    G_An , Sep 10, 2021 :
    I had contact with the customer support (OnePlus 6). They told me the ANC setting is not available on Android 10. So if you want it, you need to update to Oxygen OS 11 to get that function.
    Further i asked if this will be available in the future and they told me they can not give me any time when it will be available. I hope they will add this setting or update to OS 11 soon.
    If they don't add this, I am forced to root my phone to update manually to Android 11.
    Edit: I found a post that OS 11 for OP6 and OP6T is on the way, I guess it is just a question of time
  14. W1617728110683
    Cupcake Sep 12, 2021
    W1617728110683 , Sep 12, 2021 :
    I tried all the solutions in this thread including this one, and none of them work. I literally had to connect it to my mom's phone to get the heyMelody app to work, and then just change the settings on her phone
  15. U1632135777235
    Cupcake Sep 20, 2021
  16. dhruv.gupta98
    Cupcake Sep 24, 2021
    dhruv.gupta98 , via OnePlus 6 , Sep 24, 2021 :
    Hey even I have OP6 and facing the same issue. If the issue is resolved on your phone can you guide me too?
  17. saif1233
  18. dhruv.gupta98
    Dresa91 likes this.
  19. saif1233
