3
Oneplus Buds Pro Transparency Mode via OnePlus 7 Pro
  1. ywen1306
    Donut Sep 13, 2021
    ywen1306 , via OnePlus 7 Pro , Sep 13, 2021 :
    Hello family~
    I have a question about the OnePlus buds pro transparency mode. Is it possible to disable it? I like it sometimes, but it sometimes turns on itself for some reason, I didn't touch it either. Most of the time it's immediately transparency mode when I put on the buds. I just want to keep it normal until I change it myself.
    Any solutions? Thank you~
  2. J1597871282666
    Cupcake Oct 9, 2021
    J1597871282666 , Oct 9, 2021 :
    Same here, did you find a solution?
  3. ywen1306
    Donut Oct 13, 2021
    Sippie likes this.
  4. Itsemethev
    Cupcake Nov 1, 2021
  5. Quidan
    Cupcake Nov 29, 2021
    Quidan , Nov 29, 2021 :
    Same here. Every time i put on my earbuds there's transparency mode enabled. I want them to work by default with turned off transperency or ANC.
  6. barnabyj
    Honeycomb Nov 29, 2021
    barnabyj , via OnePlus 7 Pro , Nov 29, 2021 :
    They will default to transparency mode if only one bud is detected in your ear. Often I find my left one isn't being detected as well with the latest firmware. When I put them in and they are detected correctly, they will be in the last mode I used. You also cannot turn on anc, if they aren't detected in your ear. You may want to disable this feature to help with this. I also run the ear bud fit test often to make sure they're in and are making a good seal.
  7. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Community Expert Nov 29, 2021
    Liehjan , Nov 29, 2021 :
    Turn off in ear detection.
  8. ywen1306
    Donut Nov 30, 2021
    ywen1306 , Nov 30, 2021 :
    I'll try that~ thank you!
    Liehjan likes this.
  9. JacobR
    Cupcake Jan 11, 2022
    JacobR , via OnePlus 8 , Jan 11, 2022 :
    I have the same issue, the transparency mode only turns on if I have only one earbud in ear ( I like to use one earbud a lot so its not that the earbud is not detected or something) and its a little annoying. I want to have my one earbud but it automatically turns on transparency mode. If I want to use one earbud I have to turn off the transparency mode every time im using one earbud by holding my earbud for a second so it goes to "off" mode. Wish I could have one earbud on and having the mode set to "off" automatically even with one earbud in my ear.
  10. weenss
    Cupcake Jan 18, 2022
    weenss , Jan 18, 2022 :
    How do I turn off in ear detection? I've looked in Hey Melody and haven't been able to find it anywhere unfortunately. This would be perfect, as I've been having tons of issues with the buds not registering as being in my ears, despite the fact they're already in my ears, and I have to waste time wiggling them around in order for them to register as being 'in my ears'
  11. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Community Expert Jan 19, 2022
    Liehjan , Jan 19, 2022 :
    Unfortunately I only have a OnePlus device, and heymelody don't work so can't check... I use buds app and there is the option to turn off in ear detection.
  12. anyk8
    Donut Jan 19, 2022
    anyk8 , Jan 19, 2022 :
    You probably have not updated your buds app because it's there in my OnePlus 6 device
  13. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Community Expert Jan 20, 2022
    Liehjan , Jan 20, 2022 :
    I think you quoted the wrong person :)
