21
OnePlus Buds Z bugs/issues
  1. zervinb
    Gingerbread Dec 29, 2020
    zervinb , via OnePlus 6T Mirror Black , Dec 29, 2020 :
    Try enabling Bluetooth Absolute Volume. If already enabled, disable and enable it again.
    #61
    josuediaz127 likes this.
  2. A1558464759398
    Cupcake Dec 29, 2020
    #62
  3. zervinb
    #63
  4. Devansh.Gala
    Cupcake Dec 30, 2020
    Devansh.Gala , via OnePlus 6 , Dec 30, 2020 :
    I have been facing this issue i don't know if any of you are facing this too but my buds case fits a bit loose and not the right fit it's not very loose but it doesn't fit like how airpods case fits, i think it has some defect let me know if you'll are facing the same issues.
    I'll share the photos as well
    It is loose on one side and tight on another
    #64
  5. Vemula sreeram
    Froyo Dec 31, 2020
    #65
  6. reeshabhkumarranjan
    Cupcake Jan 2, 2021
    reeshabhkumarranjan , Jan 2, 2021 :
    I am on 342.242.232. Still audio breaks/cracks/stutters/pauses for 1-2 seconds and comes back. Happens every 10-15 seconds. I will try turning off and on the Bluetooth Absolute Volume and test it and revert back.
    #66
  7. A1558464759398
    Cupcake Jan 4, 2021
    A1558464759398 , via OnePlus 7 Pro , Jan 4, 2021 :
    same issue with me too
    #67
  8. Darshanburad
    Cupcake Jan 5, 2021
    #68
  9. cr1411
    Eclair Jan 18, 2021
    cr1411 , via OnePlus 7 , Jan 18, 2021 :
    Not worked bro!
    #69
  10. pratap1151
    Cupcake Jan 22, 2021
    #70
  11. pratap1151
    #71
  12. G_Shams_Rehan_NxCz
    Gingerbread Feb 20, 2021 at 10:21 AM
    G_Shams_Rehan_NxCz , Feb 20, 2021 at 10:21 AM :
    these issues really need to get fixed, it's just horrible. the music plays pretty well when it's working properly. other than that. Disappointed.
    #72
  13. G_Shams_Rehan_NxCz
    Gingerbread Feb 20, 2021 at 10:22 AM
    #73
  14. Pranjal.Goel.16
    Honeycomb Feb 20, 2021 at 12:06 PM
    #74
  15. kartikparmarr
    Cupcake Feb 22, 2021 at 6:03 AM
    kartikparmarr , Feb 22, 2021 at 6:03 AM :
    The buds are too sensitive with auto pause system. Even though it's a little loose in ear, it considers it as removed and the music pauses. It's too annoying, any solutions?
    #75
