OnePlus Buds Z Call Quality via OnePlus 6T
  1. sungkd
    Gingerbread Nov 18, 2020
    sungkd , via OnePlus 6T , Nov 18, 2020 :
    Firmware 328.328.232
    Device OnePlus 6T
    I received my new OnePlus Buds Z on 17th November 2020 and I'm pretty impressed by the sound quality and features.
    I got a firmware update as soon as I connected the buds for the first time.
    Only problem is when I'm in a call the voice is pretty low, the other person can hear me but the incoming voice is really low.
    Is it because of the firmware issue or is it a hardware issue or am I missing any settings?
    Please suggest
    Thanks
  2. rsolomonjr1
    Cupcake Nov 18, 2020
    rsolomonjr1 , Nov 18, 2020 :
    I have the same issue. They say they can hear me well, but on my end it sounds like I'm under water
    sungkd likes this.
  3. sungkd
    Gingerbread Nov 19, 2020
    sungkd , via OnePlus 6T , Nov 19, 2020 :
    Yes pretty much the same issue. What should I do?
    It's only been 2 days should I replace the buds or wait for firmware update?
  4. K1603007232530
    Cupcake Nov 19, 2020
    K1603007232530 , via OnePlus 8T , Nov 19, 2020 :
    For me low sound seems to be an issue during media playback as well!
    Have to keep volume levels at or above 90 keep the sound decently loud...At volume levels of 50 and so, they sound unreasonably low...!
    Have asked for replacement now but do u think that this is a firmware issue and can be rectified with an update? P.S- My current firmware is 328.
  5. Y1593889199261
    Cupcake Nov 20, 2020
  6. Nishar23
  7. JaiDedhia
    Cupcake Apr 8, 2021 at 8:06 PM
    JaiDedhia , via OnePlus 7T Pro , Apr 8, 2021 at 8:06 PM :
    I also purchased the OnePlus Buds Z on 6th of April and they got delivered on 8th April and I was facing the same problem as well
    So just do the following steps and it may troubleshoot the problem
    Whenever on call using OnePlus Buds Z just reduce the volume and suddenly increase it back to full, the problem will be resolved in most of the case
    Do leave a like if the problem is solved using the same method
