2
Oneplus Buds Z - Left Bud Battery Draining Faster via OnePlus 7T Pro
  1. rohitkhannayahoo , via OnePlus 7T Pro , Nov 13, 2020 :
    My OP Buds Z is having battery issue as battery on Left Bud is draining faster than right one inspite of both the buds are fuy charged at the same time and also using for the same time.
    Solace_Serenity and Rishabh0179 like this.
  2. Rishabh0179
    Froyo Nov 13, 2020
    Rishabh0179 , via OnePlus 6 , Nov 13, 2020 :
    Hi.
    I too got my OnePlus buds z delivered today 13 nov and I am facing the issue. The left bud is draining faster than the right bud. And also my right bud is never showing 100% despite I charged it fully. I don't know what to do.
    Does anyone have any suggestions?
    Or shall i apply for replacement
    rohitkhannayahoo likes this.
  3. Rishabh0179
    Froyo Nov 13, 2020
  4. rohitkhannayahoo , via OnePlus 7T Pro , Nov 13, 2020 :
    I talked to customer care and they suggested me to go to service center in your city. In case service center found any fault in budz then they will replace the buds hand to hand subject to availability of stock with them.
    JILESH M A and Rishabh0179 like this.
  5. Rishabh0179
    Froyo Nov 13, 2020
    How they are supposed to check if there is fault or not? as i don't have service center in my city, it is not possible for me.
    And this buds z is out of stock in online site how we can expect availability of buds in service center 😂😂😂.
    JILESH M A and rohitkhannayahoo like this.
  6. #6
  7. Rishabh0179
    Froyo Nov 13, 2020
    There is a difference in battery percentage with most of us. So all products have a fault? It's quite hard to judge. There must be some other way.
    I got my buds z delivered today. If I can know it is faulty or not in some way myself then I can ask for a replacement online.
  8. #8
    Rishabh0179 likes this.
  9. Rishabh0179
    Froyo Nov 14, 2020
  10. E1586873238653
    Cupcake Dec 20, 2020
  11. zervinb
    Gingerbread Dec 21, 2020
    zervinb , via OnePlus 6T Mirror Black , Dec 21, 2020 :
    A slight difference in battery drainage between the left and right Buds is normal. Approximately a difference of 5-10% in battery level between the Buds can be expected. If it is more than that, then it may indicate a fault.
  12. AashishAb
    Cupcake Jan 28, 2021
  13. georgeenciu
    Cupcake Jul 28, 2021
    Solace_Serenity likes this.
  14. Solace_Serenity
    Froyo Aug 23, 2021
    Solace_Serenity , Aug 23, 2021 :
    How the heck does that even happen?
    Battery case not closed all the way? 3rd part ear tips not having them sit properly on the contacts? Dirty contact points? @georgeenciu
