4
Oneplus Buds Z Pin ? Tried resetting didn't help via OnePlus 8T
  1. AbhiPan
    Donut Oct 29, 2020
    AbhiPan , via OnePlus 8T , Oct 29, 2020 :
    Hi all,
    Would appreciate a response.
    I tried pairing the Buds Z with phone but it's asking for a pin code; I tried 0000 / 1234 it doesn't work.
    Tried to reset the device by long pressing button on case as well but it still asks for pin when connecting .
    Any ideas how to get the pin code ?
  2. I1594383813378 , via OnePlus 8 Pro , Oct 29, 2020 :
    Hello.
    When the white light blinks
    I'm Bluetooth settings
    U will get 2 option
    1. Bluetooth icon OnePlus buds z
    2. Headset icon OnePlus buds z
    Click on the headset icon buds will get connected
    AbhiPan likes this.
  3. AbhiPan
    Donut Oct 30, 2020
    AbhiPan , via OnePlus 8T , Oct 30, 2020 :
    I tried that all I am getting when holding the reset button is a green light
    I held it for 2 s and even longer the light doesn't change to white .
  4. I1594383813378 , via OnePlus 8 Pro , Oct 30, 2020 :
    It should change read the manual that comes with the box step by step process is written over there
    AbhiPan likes this.
  5. AbhiPan
    Donut Oct 30, 2020
    I tried as per manual actually... No difference .. might have to take it to the service center
    Quite disappointed with this device tbh.
    thanks a lot for your help either way 😃
  6. Siddhartha16
    Gingerbread Oct 30, 2020
    Siddhartha16 , via OnePlus 7 Pro , Oct 30, 2020 :
    It is written in the manual. To reset the buds, do the following:
    1. Open the case, but keep the Buds inside.
    2. Press the reset switch for 10 seconds.
    3. The led on the case will turn to red.
    4. Leave the reset switch.
    5. Re-pair the Buds.
    AbhiPan likes this.
  7. AbhiPan
    Donut Oct 30, 2020
    I'm so dumb lmao
    I didn't realise the case needs to open when resetting!!
    Thanks a lot Siddartha!!
    riyasaraf59 and Siddhartha16 like this.
  8. Siddhartha16
    AbhiPan likes this.
  9. #9
    AbhiPan likes this.
  10. AbhiPan
    Donut Oct 30, 2020
  11. Swaran200
    Cupcake Oct 30, 2020
    Swaran200 , Oct 30, 2020 :
    There is not even fast pairing support for OnePlus 6T. I was hoping for it.
    Tried everything , The buds are no pairing woth my OnePlus 6t. Either by fast pairing or by manual bluetooth , it asks for passcode
  12. F_Harshal_Rakhra_qcit
    Cupcake Nov 2, 2020
    F_Harshal_Rakhra_qcit , Nov 2, 2020 :
    Same with my OnePlus 7, I have to pair it again with the OP7 after opening the case. Moreover, connecting with the laptop is much more difficult. Again and again the same window to enter Pin code pops up. Anybody having solution for fast pairing will be highly appreciable
  13. Swaran200
    Cupcake Nov 2, 2020
    Swaran200 , via OnePlus 6T , Nov 2, 2020 :
    For me the most annoying issue is mic. The person on the other end cant understand anything. He just hears a blurry sound. Is it the same with you or should i replace it ?
    P.S. for pairing i just had to pair one time manually. Now when i open my buds case , it automatically gets connected.
  14. Dixant46
    Cupcake Nov 2, 2020
    Dixant46 , Nov 2, 2020 :
    Follow these steps to use your buds on multiple devices:
    1. Open your case (with buds inside) and connect with your mobile (Pairing shouldn't require code)
    2. After connecting to your mobile, press power button at back of the case for few seconds until you see white light
    3. Once you see white light, open Bluetooth settings on your laptop/other device and pair it with buds (shouldn't ask you for code to pair if you followed prior steps)
    4. Viola, your buds are connected now with your other Bluetooth device
    Note, you can actively connect your buds to only one device. For you to quick switch between your Bluetooth devices, you have to press on the touch area on your buds for about three seconds, your buds will automatically switch active connection between the devices (Bluetooth should be on in both devices).
    Hope this helps!
    Z1603914615561 and Tarun Rag like this.
  15. Dixant46
    Cupcake Nov 2, 2020
    Considering Buds Z has only two mic, the mic quality would be bad for outdoor conditions (windy/noisy environment). Try testing the mic quality in a closed environment and see if it still blurry and not clear then you may try to go for a replacement as the mic might be buggy.
  16. R1603540467039
    Cupcake Nov 2, 2020
    R1603540467039 , Nov 2, 2020 :
    would appreciate a response
    I do have the same problem. while connecting in pc its asking to enter code
  17. Sid_Ck
    Ice Cream Sandwich Nov 2, 2020
    Sid_Ck , Nov 2, 2020 :
    Press the back button for 3-4 secs the white light will start blinking and then it's in pairing mode you can connect to Laptop
  18. R1603540467039
    Cupcake Nov 2, 2020
    Thank you so much man, it worked !!!
    I really appreciate it I tried factory reset but when it's on white indicator it paired thank you so much
  19. Sid_Ck
    Cheers
  20. Dr.Sucio
    Cupcake Nov 13, 2020
    Dr.Sucio , Nov 13, 2020 :
    Just got them not even 10 mins ago......can't connect them at all. Been running around youtube to see how to connect them, and still no connection. I leave the case open next to my OnePlus 8 that is updated, I have the OnePlus Buds app installed.....still no connection. I turn on bluetooth, still no connection. I find them under pair new device, tap them and it tells me to put a pairing code "0000 or 1234" I do so and then my phone goes haywire. Stays saying connecting, then stops then I see a message pop up "bluetooth turned off/bluetooth turned on" 🤦🏻‍♂️🤦🏻‍♂️🤦🏻‍♂️ wtf is going on? Not even 20 mins with these things and already having issues. CAN SOMEONE HELP!?
