17
OnePlus Buds Z Sound Freeze issue via OnePlus 5T
  1. Abhinav KR
    Donut Nov 8, 2020
    Abhinav KR , via OnePlus 5T , Nov 8, 2020 :
    Have been using buds Z since the past 2 days and i have been experiencing a sudden voice drop, like for about a second, frequently, which has really started to annoy me! PLEASE TELL IF YOU ARE FACING THE SAME ISSUE AND IF THERE IS AN ISSUE FOR IT YET!
    [UPDATE]: A new firmware(328) update is launched by Oneplus, but the problem still persists, however, the frequency of the problem has reduced
  2. #2
    Abhinav KR and MuditAchSharma like this.
  3. ujjwalking
    Donut Nov 9, 2020
    ujjwalking , via OnePlus 8T , Nov 9, 2020 :
    I am facing the same issue, mostly happens while playing game(not game issue for sure). Its so annoying that i have stopped using it. @OnePlus can you please take a look into it and fix it asap with an update.
  4. isagar3
    Donut Nov 9, 2020
  5. ujjwalking
    Donut Nov 9, 2020
  6. isagar3
    Donut Nov 9, 2020
  7. Shailendra_Shambhu
    Cupcake Nov 9, 2020
    Shailendra_Shambhu , Nov 9, 2020 :
    Did you update it manually or it was an OTA update?
  8. isagar3
    Donut Nov 9, 2020
  9. ujjwalking
    Donut Nov 9, 2020
  10. isagar3
    Donut Nov 9, 2020
  11. Shailendra_Shambhu
    Cupcake Nov 9, 2020
    X1559331690913 likes this.
  12. #12
  13. X1559331690913
    Cupcake Nov 9, 2020
  14. Ayanprmnk93
    Donut Nov 10, 2020
  15. M1559833705609
    Cupcake Nov 10, 2020
    M1559833705609 , Nov 10, 2020 :
    How do you check which firmware you have?
  16. Ayanprmnk93
    Donut Nov 10, 2020
  17. ShivanshTyagi21
    ShivanshTyagi21 , via OnePlus 8 , Nov 10, 2020 :
    I had the same issue as well I thought I've been given a faulty piece I replaced it and still it wasn't working so I had to return it finally can someone please tell if this issue has been resolved?
  18. Ayanprmnk93
    Donut Nov 10, 2020
    Ayanprmnk93 , via OnePlus 8 Pro , Nov 10, 2020 :
    its a gaming mode compatibility issue.. will be fixed with a firmware update..
    idk how only one person got that update.
  19. Abhinav KR
    Donut Nov 10, 2020
  20. ShivanshTyagi21
    I just received an update to security patch 2020.10 and it says that bluetooth low probability connectivity issues have been solved can somebody please confirm the same and if the buds are working fine now because I'll have to re-purchase it.
