Oneplus buds z via OnePlus Nord
  1. MALLIKARJUNA NAIK
    Cupcake Dec 13, 2020
    MALLIKARJUNA NAIK , via OnePlus Nord , Dec 13, 2020 :
    I had bought oneplus buds z ,it shows different battery level for each bud ,I had fully charged it and started with 100 percent ,after using a while it's shows left 90 and right 86 ,then after a while it shows both 82 ,mean a while it shows left 76 and right 74 ,is it could be normal or any defect in it
  2. kppnesh
    Cupcake Dec 15, 2020
  3. Vishwanath.
    Cupcake Dec 18, 2020
    Vishwanath. , via OnePlus Nord , Dec 18, 2020 :
    This happens with all TWS buds and not only Buds Z. If the difference between the two buds is between 5-9% it's normal. But if it exceeds 10%, then it's a matter of concern.
  4. Rajendra.Bhat
    Jelly Bean Dec 18, 2020
  5. Satya U
    Froyo Dec 20, 2020
  6. MALLIKARJUNA NAIK
    Cupcake Dec 20, 2020
    MALLIKARJUNA NAIK , via OnePlus Nord , Dec 20, 2020 :
    Almost all of them reporting the same issue .soo I think it's may be normal .the difference between the two buds should be within 1 to 5 beyond that could be considered otherwise it's been normal .I have seen many soo I myself have same issue .may be fixed through update wait for it .if u gonna replace the other buds also have the same .so just wait for it
    Satya U likes this.
