Oneplus bullet wireless, low phone call volume
  1. DonWuwn
    Froyo Jun 12, 2018
    DonWuwn , Jun 12, 2018 :
    Did I get a dud? Extremely low voice coming through the other end. Like I have it 1 level above silent. Music playback gets really loud.
    subasisgolder likes this.
  2. DonWuwn
    Froyo Jun 12, 2018
  3. Rynorak
    Froyo Dec 29, 2018
    Rynorak , Dec 29, 2018 :
    I have the same problem. Worked fine at first, now I can barely hear people I'm talking to on the phone.
  4. Rynorak
    Froyo Dec 30, 2018
    Rynorak , Dec 30, 2018 :
    problem solved. All working fine thanks to calling support. I just had to reset all wireless networks.and start over. Noemi have full in call volume [e]1f44d[/e][e]1f44d[/e]
  5. Rynorak
    Froyo Dec 30, 2018
  6. Pulin Mistry
    Cupcake Jan 16, 2019
    Pulin Mistry , Jan 16, 2019 :
    how to fix the issue..? I am facing same problem of low volume voice call...
  7. Rynorak
    Froyo Jan 16, 2019
    Rynorak , Jan 16, 2019 :
    OnePlus suggested resetting all my remembered connected devices including Bluetooth, WiFi etc. Options, reset, WiFi, Bluetooth.
  8. kanakareddy
    Cupcake Aug 27, 2019
    kanakareddy , Aug 27, 2019 :
    Even then the call volume is very low
  9. Pragati260292
    Cupcake Aug 31, 2019
    Pragati260292 , Aug 31, 2019 :
    Can someone please help with this low call volume problem ? The Call Volume is too low and the Noise Cancellation is also not good..
  10. Maskedillusion
    Cupcake Feb 1, 2020
    Maskedillusion , Feb 1, 2020 :
    You just have to make the volume low and then high again
  11. Maskedillusion
    Cupcake Feb 1, 2020
    Type 'reset wifi' in settings and you'll get an option to 'Reset Wifi , Network and Bluetooth connections'. Note that you will lose all your saved Bluetooth and WiFi connections when you agree to reset the settings . After which pair your bullets wireless again and turn your Bluetooth volume all the way down and back up to high and it will solve it .
    rahulnairdgr8 and Pragati260292 like this.
  12. Y1577169210654
    Cupcake May 21, 2020
    Y1577169210654 , May 21, 2020 :
    Didn't solve the issue .. i i did reset the wifi & Bluetooth settings, still the volume is too low .
  13. Maskedillusion
    Maskedillusion , via OnePlus 6 , May 21, 2020 :
    Also , I temporarily lose audio volume in either side if you guys manage to make it wet . In any case just sort of immerse it in iso propyl alcohol (both the sides and the mic and the charging port)!
  14. Y1577169210654
    And this fixed it: Turn off Bluetooth __ Go to setting - Apps & notifications - see all apps Tap on the three dots on the top right and Show System. Now go to Bluetooth and delete storage
    It should work after that
    L1600093655008 likes this.
  15. L1600093655008
    Cupcake Sep 14, 2020
    L1600093655008 , Sep 14, 2020 :
    this works thank you
  16. Rajendra.Bhat
    Jelly Bean Sep 14, 2020
    Rajendra.Bhat , Sep 14, 2020 :
    Type App& notif.. in settings search bar.click on see all apps - Show system in action menu (3 dots in the top right corner) Bluetooth - delete storage & cache
  17. ytreddy
    Honeycomb Sep 17, 2020
    ytreddy , Sep 17, 2020 :
    Thanks...worked for me... :)
