4
OnePlus bullet wireless z - Mic issue via OnePlus 6
  1. Vaibhav kumar
    Donut Jul 15, 2020
    Vaibhav kumar , via OnePlus 6 , Jul 15, 2020 :
    Second person says my mic volume is very low they can barely listen my voice . My product delivered on 9th of June . How to replace/repair my earphones?
  2. iammrkt
    Gingerbread Jul 18, 2020
    Zeeshan_Ali likes this.
  3. Vaibhav kumar
    Donut Jul 21, 2020
    Vaibhav kumar , via OnePlus 6 , Jul 21, 2020 :
    There is no option to replace or repair even they just gave me an excuse of covid that they are giving option only on orders of last 7 days.
  4. iammrkt
    Gingerbread Jul 23, 2020
    iammrkt , via OnePlus 6 , Jul 23, 2020 :
    Bro can you tell how much score will you give out of 10 on below parameters please ?
    1. Sound quality
    2. Connection speed(how fast it connects)
    3. Device switching speed
    4. Stability of connection (whether it disconnects automatically sometimes )
    5. Comfort of use (specially for long hours)
    6. Call quality
    7. Button functionalities (whether the buttons actually work everytime as intended when u press them like next track previous track)
    8. Google assistant (whether assistant works everytime u activate it )
    Based on your feedback i will consider buying or else i will cancel the orde..
  5. sharonsadasivan
    Cupcake Jul 27, 2020
    sharonsadasivan , Jul 27, 2020 :
    I have been using wireless z for a while
    only issue that I face is about abnormal behaviour of mic. person at the other end is not able to hear my voice. and that's a major issue when you buy for calls
    everything else is fine
  6. X1539193659689
    Cupcake Jul 28, 2020
    X1539193659689 , Jul 28, 2020 :
    Go for it only if you are using it for movies, pubg.
    It has low latency mode.
    Mic is so poor that every time it will make you embarrassed while calls. You have disconnect it.
    Saggigo and Vaibhav kumar like this.
  7. h.zafari
    Cupcake Nov 23, 2020
    h.zafari , via OnePlus 7 , Nov 23, 2020 :
    1. I'm mostly using it for voice call and the quality was acceptable.
    2- it's just normal, I'd been using huawei freelace 2 with my OnePlus 7 and the connection speed was almost the same.
    3- same as number 2
    4- sometime specially in high noise environment
    5- I am not comfortable with in canal earphone, I do prefer old airpod or samsung level U earphone
    6- normal
    7- not a fan, I have no idea
    8- same as 7
    Well I can only tell you that
  8. MangeshL09
    Cupcake Dec 2, 2020
    MangeshL09 , via OnePlus 7 , Dec 2, 2020 :
    During calls, other person on the phone complaints that he can't hear me and then I have to remove headphone and speak with them through cell...
    Saggigo likes this.
  9. dosten
    Donut Dec 9, 2020
    dosten , Dec 9, 2020 :
    I recently bought these and at first they were working flawlessly but since past few days I was also facing this problem. The person on the other side would not be able to hear me. I had to re-pair the headphones with my oneplus 7 and since then they're working fine.
  10. AyushRathore114
    Cupcake Dec 19, 2020
    AyushRathore114 , via OnePlus 8 , Dec 19, 2020 :
    My OnePlus bullet wireless z bass edition mic is not working , when I blow air in it the mic start and after sometime time it didn't respond please tell me solution
    Saggigo likes this.
  11. #11
    Saggigo likes this.
  12. Saggigo
    Eclair Dec 23, 2020
    Saggigo , via OnePlus 6 , Dec 23, 2020 :
    How many claims should the customers do to have a solution from support service???
    I have bought my Bullet z since 4 months ans didn't use them yet, this is the worst support i have ever seen
  13. U1608904344091
    Cupcake Dec 25, 2020
    U1608904344091 , via OnePlus 7 , Dec 25, 2020 :
    It us because your phone is using its own mic not the headset's mic keep your phone close to you while talking to someone or you can download a app called open camera and go to its settings select microphone select external mic🤗
    Za3ymm likes this.
  14. Saggigo
    Eclair Dec 26, 2020
    Saggigo , via OnePlus 8T , Dec 26, 2020 :
    Are u serious???
    Buying a phone and a headset and to solve the issue download an app???
    Please, give us a final solution or walk away
    Manmohan15214 likes this.
  15. L1598030206530
    Cupcake Dec 28, 2020
  16. Za3ymm
    Eclair Dec 28, 2020
    Za3ymm , via OnePlus 7 Pro , Dec 28, 2020 :
    Thanks for the solution. It is force the phone to use bluetooth or tws mic in other apps like pubg.
    Saggigo likes this.
  17. Saggigo
    Eclair Dec 31, 2020
  18. Saggigo
    Eclair Dec 31, 2020
    Saggigo , via OnePlus 8T , Dec 31, 2020 :
    I have tried this solution with open camera abs it doesn't work
  19. h.zafari
    Cupcake Jan 29, 2021
    h.zafari , via OnePlus 7 , Jan 29, 2021 :
    Is it fixing the problem?
  20. Sandykahlon
    Eclair Feb 9, 2021
    Sandykahlon , via OnePlus 6 , Feb 9, 2021 :
    Same issue, Mic issue Distrubing sound on others phone while calling. Normal call, whatsapp and zoom.
    had replaced ones but no solution.
    and Earphones work fine with other Realme MI phones. Not with OnePlus 6.
    But other Wireless earphones work fine with OnePlus 6.
    IT is surely a software bug , they are not fixing it , seems like they want us to buy new gen phone.
