Oneplus bullet wireless z problem via OnePlus 6
  1. Anas Multani
    Donut Jul 10, 2020
  2. Swatiranjan
    Jelly Bean Jul 10, 2020
  3. Viraj Pnvs
    Eclair Jul 14, 2020
  4. Batman360
    Lollipop Jul 14, 2020
    Batman360 , Jul 14, 2020 :
    Kindly factory reset the earphones by holding the volume up and down buttons together for 5-10secs until the light stops blinking. Then start them normally, it should work fine.
  5. Viraj Pnvs
    Eclair Jul 14, 2020
    Viraj Pnvs , via OnePlus 8 Pro , Jul 14, 2020 :
    Thanks, but not even able to reset it, that's the problem.
  6. Batman360
    You have to seperate the earbuds first, detach them from each other....and then press and hold the 2 buttons I told you earlier
  7. Viraj Pnvs
    Eclair Jul 14, 2020
    the same I did brother, no response.
  8. Batman360
    What issue do you have to be precise?
  9. Viraj Pnvs
    Eclair Jul 14, 2020
    Charged it, after pulling off, the white light doesn't turn off irrespective of what I do.. even not able to connect.
  10. Batman360
    Press and hold the button on the collar of the earphones until the light turns off
  11. Viraj Pnvs
    Eclair Jul 15, 2020
  12. OslerWeberRendu
    Cupcake Jul 16, 2020
  13. Viraj Pnvs
    Eclair Jul 17, 2020
    Viraj Pnvs , via OnePlus 8 Pro , Jul 17, 2020 :
    solution I saw somewhere is to leave the buds discharge for a week or so, and then charge and continue. I'm trying that already
    G_Naveen_K_Tency_LPvB likes this.
  14. J1529387456270
    Cupcake Jul 18, 2020
    J1529387456270 , via OnePlus 6 , Jul 18, 2020 :
    Still the problem is there ,
    While on call it automatically disconnects....
  15. Batman360
    Lollipop Jul 18, 2020
    Batman360 , Jul 18, 2020 :
    Contact customer care.
  16. OslerWeberRendu
    Cupcake Jul 19, 2020
    OslerWeberRendu , Jul 19, 2020 :
    It worked.. thankyou..🤩
  17. K1595173685590
    K1595173685590 , via OnePlus 6T , Jul 19, 2020 :
    I purchased a new wireless z. But when i detach the earphones then I'm not getting white light and not turning on even i pressed the button. Any solution for getting this worked?? I really feel so bad about seeing these many people facing same problem. 1 plus should improve the quality really.
  18. Viraj Pnvs
    Eclair Jul 19, 2020
    Viraj Pnvs , via OnePlus 8 Pro , Jul 19, 2020 :
    Did you try charging them atleast once?
  19. K1595173685590
  20. Viraj Pnvs
    Eclair Jul 19, 2020
