23
Oneplus Bullets Wireless Q&A, User Manual, Reviews etc.
  1. GarageRamen
    Gingerbread Jan 5, 2019
    GarageRamen , Jan 5, 2019 :
    I have a question that I've searched for and can't seem to find the answer. First, I know that the Dash Charger that comes with the 6T will charge the Bullets Wireless. But, can anybody tell me is it okay to use the Warp Charger from the McLaren 6T and charge the Bullets Wireless without damaging them?
    #41
  2. Venky61
    Jelly Bean Jan 5, 2019
    Venky61 , Jan 5, 2019 :
    Hi... Technically it behaves the same with warp charger as it does with dash charger. It will only draw the power required. The charging speeds won't increase.
    #42
    GarageRamen likes this.
  3. GarageRamen
    Thank You Venky61!
    #43
    Venky61 likes this.
  4. Forest98
    Donut Jan 6, 2019
    Forest98 , Jan 6, 2019 :
    I'm using OxygenOS 9.0.11 on OnePlus 6T. Recently, the magnet play/pause function didn't work.
    Is there any way to solve this? Thanks.
    #44
  5. Venky61
    Jelly Bean Jan 6, 2019
    Venky61 , Jan 6, 2019 :
    Is it a one time thing or its not working at all?
    I just updated to 9.0.11, will check that and get back to you.
    #45
  6. Forest98
    Donut Jan 6, 2019
    I tried several times and even reset the earbuds, and still didn't work as I just checked again. Also, this problem exists on Open Beta 2. But, I'm not sure is this a hardware problem or software issue. I didn't drop earbuds into water before.
    #46
  7. Venky61
    I just tried and its working on my 6T. Tried couple of Apps and play/pause worked without any issue.
    If only the resume is not working, just check the resume option in bluetooth settings.
    #47
  8. Forest98
    Donut Jan 6, 2019
    Where can I find that setting?
    #48
  9. Venky61
    Settings>Sound>Earphone Mode> Autoplay
    #49
  10. Forest98
    Donut Jan 6, 2019
    I tried again when I saw your previous reply. At that time, the play/pause function magically worked. But, when I started playing music. It failed again. Maybe it's my earbuds hardware malfunction.
    #50
  11. Venky61
    Possible. Drain the battery and charge it back to 100% and check.
    #51
  12. Forest98
    Donut Jan 6, 2019
    Should I drained earbuds to auto shut down?
    #52
  13. Venky61
    Yes exactly...Just a random try.
    #53
  14. jignesh_kc
    Cupcake Jan 6, 2019
    jignesh_kc , Jan 6, 2019 :
    Two problems I felt.
    1)It doesn't give any indication of low battery in terms of sound
    2) call is not getting disconnected using magnetic ear bud concept.
    #54
  15. Forest98
    Donut Jan 6, 2019
    It has a sound at 10% low battery
    #55
  16. jignesh_kc
    Cupcake Jan 6, 2019
    #56
  17. Venky61
    1. It does give a small tone during low battery. Its not too noticeable and you can get confused it with your regular notification sound.
    2. Call is not supposed to be disconnected with magnets snapped. Its to only play and pause. The assistant button on the earphone does that job.
    #57
  18. jignesh_kc
    Cupcake Jan 6, 2019
    Thank you
    #58
    Venky61 likes this.
  19. A1534079167765
    Cupcake Jan 7, 2019
    A1534079167765 , Jan 7, 2019 :
    My bullets won't reconnect by bluetooth when I separate the magnets. I have to pair them again with the 6T to work.
    Any idea?
    #59
  20. Forest98
    Donut Jan 7, 2019
    Forest98 , Jan 7, 2019 :
    I have same problem, too. Currently, still work with support agent asking them to let me send back my earbuds for a repair.
    #60
