23
Oneplus Bullets Wireless Q&A, User Manual, Reviews etc.
  1. iamsaifahamed Eclair Apr 19, 2019
    iamsaifahamed, Apr 19, 2019 :
    I have recently bought oneplus bullets wireless. To be frank the initial impressions were great for its packaging but when i started using i felt its not worth the hype.First thing i noticed was that the Bluetooth rage is very less and weak.
    The most annoying thing came later while i was texting my friend on whatsapp while my wireless bullets are still connected. The tone was noticeably noisey for every message i receive and sent. When i tried to decrease volume there was no sign of tone but just the noise. I tried resetting but no use. Later i found out its the same case when there is silence followed by slow music.
    Anyone faced the same issue?
  2. Venky61 Jelly Bean Apr 24, 2019
    Venky61, Apr 24, 2019 :
    Thanks for sharing your experience here. I heard similar stories from others as well. Only couple of them had to wait longer for resolving.
    Did you try using the Absolute Volume Option in Settings?
    Yes the bass is less and noise cancellation isn't the best. You can provide your feedback here https://forums.oneplus.com/feedback/ where there are chances that they can look into it. This thread is a user one.
    I did not face any of the issues you mentioned. Better you get it checked at a nearby service center.
  3. P1542264936687 Cupcake Apr 26, 2019
  4. B1514717992919 Eclair Apr 26, 2019
    B1514717992919, Apr 26, 2019 :
    hey Viraj,
    even I am using on my OP3 & I agree the bass in on the lower side. As suggested by Venky, one way is to plug those tighter inside the ears. second, try some other ear buds (yes some do lead to a difference). and Currently if you download Jiosaavn app, you can use its equilizer in settings, you will notice some thump there for sure.
    and yes, if pie update resolves the existing issue, then we will get audio tuner (the native feature in One Plus settings) support for bullets wireless.
    cheers [e]1f60a[/e]
    Venky61 likes this.
  5. B1514717992919 Eclair Apr 26, 2019
    hey Venky,
    nice informative post. thanks for the effort.
    I guess the provided type-C cable is surely a dash-charge compatible one.
    Venky61 likes this.
  6. Venky61 Jelly Bean Apr 26, 2019
    Venky61, Apr 26, 2019 :
    You have to wait for the Red ones to come in stock. You can also contact the nearby Oneplus Stores if they have any in stock.
    Thank you. Glad that you find it useful. :)
    The cable I got with the Earphone is surely not Dash Charge Compatible. You are lucky if you got one ;) Check if you get "Charging Rapidly" notification.
  7. Jai_Gupta_0neplus3 Cupcake May 17, 2019
    Jai_Gupta_0neplus3, May 17, 2019 :
    Hi, can you help me to understand if the OnePlus Bullets Wireless 2 will compatible with OnePlus 3 mobile and can be charged using Dash Charger.
  8. Venky61 Jelly Bean May 17, 2019
    Venky61, May 17, 2019 :
    Yes the Bullets Wireless 2 is compatible with Oneplus 3, however the music resume feature would not work with 1+3. The magnetic pause feature works. And yes, it can be charged with Dash Charger.
  9. zervinb Donut May 18, 2019
    zervinb, May 18, 2019 :
    Hi. I just purchased the Bullets Wireless 2 for my OnePlus 6T. I had a doubt regarding the charging cable supplied. I was intending to use the cable in my car to connect my phone to Android Auto since it is a short cable. However, it does not work. Is the cable just a charging cable and not compatible with data transfer? Can other users confirm? Or have I received a faulty cable?
  10. Venky61 Jelly Bean May 18, 2019
    Venky61, May 18, 2019 :
    Hey... I just checked the cable provided along with BW ver 1 and the data transfer is working provided I turn off USB Debugging mode. So try that, change the mode to data transfer and check if it works for you too.
  11. zervinb Donut May 18, 2019
    I have never had USB debugging turned on. My USB preference is for data transfer only. The regular charger cable provided with my phone works fine for Android Auto and data transfer. The short cable provided with my Bullets 2 does not. Could you reconfirm a working data transfer with the short cable provided with your Bullets?
  12. Antgl Honeycomb May 19, 2019
  13. BellapukondaKiranvarma Eclair May 19, 2019
  14. Venky61 Jelly Bean May 20, 2019
    Venky61, May 20, 2019 :
    Yes. I have checked again and the file transfer mode works with the charging cable provided along with BW1. I would suggest you to wait for users of BW2 to check and reconfirm the same. The Lab Reviews are on their way, and they would be able to help.
    Depends on what exactly you are expecting and where you are from. IMO, there are many other options in India cheaper than BW2 that sound good. So it boils down to personal choice.
    Yea, I shall make one once the Lab Reviews are out.
  15. Antgl Honeycomb May 20, 2019
    Antgl, May 20, 2019 :
    I'm from Europe. I'm looking around for wireless earphones which are worth to buy.
  16. Venky61 Jelly Bean May 20, 2019
    Sorry..I have no idea about the options available in Europe in the same price range. But if you are looking for wireless earphones with Great Battery Life (~14hrs), Light Weight Neck Band, Great Overall Sound, Multi Point Connect, Easy Pause Resume Feature and Fast/Warp Charge then you wouldn't be disappointed.
    Antgl likes this.
  17. Hasekianx Donut May 25, 2019
    Hasekianx, May 25, 2019 :
    They unstick inside the bag and connect to the phone, we need a button to turn them off. would that be possible via software update?
  18. murfilein Donut May 25, 2019
    murfilein, May 25, 2019 :
    check the SoundMAGIC E11BT, their battery apparently lasts up to 30 hours. they're not magnetic though and dont look as high-end/quality. their sound quality is supposed to be the best though.
    Venky61 likes this.
  19. S1550727875573 Cupcake May 26, 2019
    S1550727875573, May 26, 2019 :
    Caller not hearing properly. Microphone sound is too low in Bullet Wireless 2 headset. How to fix this issue?
  20. BellapukondaKiranvarma Eclair May 26, 2019
    BellapukondaKiranvarma, May 26, 2019 :
    Did you check with the volume keys in your mobile and then from 2 headset audio is kind of ok but not that low u might have used reverse - and + give it a short in local call from ur neighbor phone and give it a short
