24
Oneplus Bullets Wireless Q&A, User Manual, Reviews etc.
  1. Venky61
    Jelly Bean May 27, 2019
    Venky61 , May 27, 2019 :
    That's one flaw in the Bullet Wireless design. And no, triple press for previous track was missing in BW1 and it couldn't be implemented in software update so I highly doubt the turn off feature could be implemented.
    Reset the pairing and try again.
  2. S1550727875573
    Cupcake May 27, 2019
    S1550727875573 , May 27, 2019 :
    okk. let me do again
  3. S1550727875573
    BellapukondaKiranvarma
    Did you check with the volume keys in your mobile and then from 2 headset audio is kind of ok but not that low u might have used reverse - and + give it a short in local call from ur neighbor phone and give it a short​
    Yeah I have tried all that things, but still the same.I have not problem with headphone speaker. Headphone sound is awesome
  4. ravijain87
    Gingerbread May 30, 2019
    ravijain87 , May 30, 2019 :
    Hi,
    I've just bought the Wireless Bullets 2 and I was wondering if anyone knows if there are any compatible foam tips available from companies like Comply / Shure etc?
  5. BellapukondaKiranvarma
    Eclair May 30, 2019
    BellapukondaKiranvarma , May 30, 2019 :
    us
    well return it and give it a short if u see the same issue then its ur mobile issue or something
  6. Venky61
    Jelly Bean Jun 2, 2019
  7. ravijain87
    Gingerbread Jun 2, 2019
    ravijain87 , Jun 2, 2019 :
    For anyone curious, you can use the Comply T500 or Tx500 foam tips with the wireless bullets V2. They are a little tight so you have to work them on, but once they are on the quality of the bullets is dramatically improved!
    Venky61 and Hasekianx like this.
  8. murfilein
    Donut Jun 5, 2019
    murfilein , Jun 5, 2019 :
    just to correct my older post, the e11bt actually do magnetically attach to each other.
    Venky61 and O1541144554007 like this.
  9. B1558257246117
    Cupcake Jun 13, 2019
    B1558257246117 , Jun 13, 2019 :
    I have bought OnePlus Bullets Wireless 2. But, they are not sounding any good in my OnePlus6T. In Audio Tuner I have tried all the settings but not sounding good. There is a distortion which I hate most. Even my 5x cheaper earphones are sounding better enough to enjoy the music with good bass. Can anyone help me to get better sound from them? Any best settings for them?
    Respond as soon as possible.
  10. O1541144554007
    Cupcake Jun 26, 2019
    O1541144554007 , Jun 26, 2019 :
    I have a problem with mine. I play mobile games on my ipad and on my OP6. My teammates are complaining that theg hear an echo from me or a screeching annoying sound. But when I change to a headset the echo would disappear. How do I go about this?
    Venky61 and B1558257246117 like this.
  11. O1541144554007
    The foam tips one from Jaybird also works.. At least for me..
    ravijain87 likes this.
  12. ravijain87
    Gingerbread Jun 26, 2019
    ravijain87 , Jun 26, 2019 :
    I managed to use the Comply Tx500. they are tight so you need to work them on but once one they are perfect [e]1f44d[/e]
    O1541144554007 likes this.
  13. A1557568912102
    Cupcake Jul 12, 2019
    A1557568912102 , Jul 12, 2019 :
    Hi everyone - For the wireless bullets 2, I'm experiencing a rather extreme jump in volume in a specific part of the volume scale. Starting from silent, I go up one click, fine - another click, fine - and the third click increases the volume way too much..that scale can't be right.
    Is this a software thing? Or is there a fix? I often need to switch between low volumes depending on where I am and the background noise, and this is so annoying because the 3rd bar for volume is way too loud to be that low on the scale.
    Venky61 likes this.
  14. irfanmoosani
    Jelly Bean Jul 12, 2019
    irfanmoosani , Jul 12, 2019 :
    I am not able to use the mic of BW2 to record voice and video, can you please document the steps to use BW2 mic for the purpose. Thanks
    Steps to replicate issue:
    1.Try recording voice using audio recording or video recording using BW2
    2. Move away from phone.
    3. Check if it records audio from phone mic or BW2.
    Venky61 likes this.
  15. Venky61
    Jelly Bean Jul 13, 2019
    Venky61 , Jul 13, 2019 :
    Hey... I am using BW2 but I don't hear any distortion of sound. Only problem is the underwhelming bass. There is never a best setting as the music taste differs from person to person. I would suggest to try out listening from another BW2 if any of your friend has one and see if you hear distortion in that too. That would clear if the defect is in your piece.
    This is strange, as the complaints till now for gaming mostly have been only audio lag. Is the same echo valid for calls too?
    I don't think there's a fix for it. These scales are not linear anymore. For example the brightness slider also is not on a linear scale.
    Hey, the recording apps are not optimized for Bluetooth Mics. Not just BW2 but you can't record the audio from any Bluetooth earphone unless the app supports it. The Cinema FV-5 for ex is one of the video recording app that supports Bluetooth mic recording. Hope this helps.
    Arsath1994 and irfanmoosani like this.
  16. O1541144554007
    Cupcake Jul 13, 2019
    O1541144554007 , Jul 13, 2019 :
    No echo on calls. Just when I am gaming.
    Venky61 likes this.
  17. Prashant Mithal
    Prashant Mithal , Jul 13, 2019 :
    worst Sound quality and the worst response i got from oneplus regarding to my earphones
    they are the worst earphone with a crackling sound
    never ever think to buy this
    4000 would be waste
  18. G_Jay_Patel_XLaV
    Cupcake Jul 16, 2019
    G_Jay_Patel_XLaV , Jul 16, 2019 :
    I am using one plus 5t and bought bullets wireless 2 yesterday, while on call the mic doesn't work, it worked for initial 10 seconds. Please fix the issue
  19. Venky61
    Jelly Bean Jul 16, 2019
    Venky61 , Jul 16, 2019 :
    That's strange.... Try resetting the device or use it with a different game/phone and check once. If it repeats, you can claim the warranty.
    What response did you get?
    Hey...Reset the earphone and try again. Does the Bluetooth connection stay while on call?
  20. G_Jay_Patel_XLaV
    Venky61
    Hey...Reset the earphone and try again. Does the Bluetooth connection stay while on call?​
    Yes, the Bluetooth was on during call, I restarted the phone and cleared the cache and for now it's fixed, hope it's not a recurring issue.
    Venky61 likes this.
