6
ONEPLUS BULLETS WIRELESS Z battery issue via OnePlus 7T Glacier Blue
  1. Nisarg23901 , via OnePlus 7T Glacier Blue , May 26, 2020 :
    Hey..i recently bought the bullets wireless z from amazon.
    It says that it gives 10 hours of battery life in 10 minutes of charge woth warp charger..I have been using the warp charge 30T for charging my bullets wireless Z..so as per the company it should charge around 50% in 10 minutes but mine shows 100% , which is strange. And the led indicator doesnt change to white even after 40-45 minutes of warp charging.
    Is this issue okk or can lead to serious battery problems in the future...
    Please reply if someone has a solution or has the same problem..
  2. rohit.devrushi
    Donut May 27, 2020
  3. J1570337725817
    Eclair May 28, 2020
    acamanchaturvedi and Nisarg23901 like this.
  4. Batman360
    Lollipop May 28, 2020
    Batman360 , May 28, 2020 :
    It shows 100% true but it's not charged 100% . No need to worry about that. Also 10mins of charge can go upto 8hrs on daily usage. The earphones will be fully charged after max 23minutes. Don't charge them more than that. If you want my advice then just charge them for 10-15mins.
  5. rohit.devrushi
    Donut May 28, 2020
    Nisarg23901 likes this.
  6. Vinay303
    Cupcake May 31, 2020
  7. Nisarg23901 , via OnePlus 7T Glacier Blue , May 31, 2020 :
    but wouldnt it get factory reseted in 3 sec.
    i tried factory resseting 2-3 times but....
  8. Rush4416
    Froyo Jun 9, 2020
    Rush4416 , via OnePlus 7 , Jun 9, 2020 :
    Hello guys,
    I just purchased OnePlus bullets wireless z few days back but noticed a weird battery drain issue.
    my headphone's battery drains like 100% -> 80% -> 30% -> and red light. Is it normal?
    what should I do? please help.
    Also, do i have to charge it with my OnePlus dash charger for 30 minutes?
  9. muthu96
    Donut Jun 19, 2020
    muthu96 , via OnePlus 3T , Jun 19, 2020 :
    i am facing same problem,i bought 1 week ago,i drained full battery,today i charge for exact 10 mins,then it shows 100%,then quickly shows 80%,but working fine,no battery draining issue
  10. P1591684408017
    Cupcake Jun 23, 2020
    P1591684408017 , Jun 23, 2020 :
    Mine wireless bullet z always shows 100% charging. It never reduces and shows 100% charging everytime.
  11. Y1593959744222
    Cupcake Jul 5, 2020
  12. asangam
    Cupcake Jul 17, 2020
    asangam , Jul 17, 2020 :
    Hey bro, What did you do to resolve this issue ? Any update, I got them a day before yesterday and My earphone is showing the same issue. Thanks.
  13. Rush4416
    Froyo Jul 17, 2020
    Rush4416 , via OnePlus 7 , Jul 17, 2020 :
    Just drain it full..charge it up to 45 mins with OnePlus charger..I used my OnePlus 7 dash charger and it took almost 45 minutes. I confirmed it from OnePlus customer care also. They said the same thing to charge fully till 45 minutes or till the led light turns white from red.
    Anyway if you are in a hurry, you can charge it for 15 mins and still get a decent backup
  14. asangam
    I am using my OnePlus 6T official charger and charging till it gets Full charge (from red to white led). The first day I got it was preety bad but todays was a bit longer. Maybe it was sitting somewhere without being charged from longtime I am guessing it is taking a quite a time to optimize the battery themself.
    I also drained battery completely and left it for charging.
    After how many days did you got the good battery backup ?
    I appreciate your prompt response.
  15. Rush4416
    Froyo Jul 17, 2020
    From the 2nd day
  16. Anilkumar.Dctr
    Donut Jul 19, 2020
    Anilkumar.Dctr , Jul 19, 2020 :
    hi... my wireless z battery is draining very fast even if I'm not using them. Last night battery was 60% and in morning it's 10%. First I thought that I had left them without attaching the magnetic tips but it was not like that. anyone else facing the same problem?? and how to resolve it?? please let me know.
    thanks
    san.nbx likes this.
  17. san.nbx
    Cupcake Jul 28, 2020
    san.nbx , Jul 28, 2020 :
    I am also facing the same issue. After some days you will find the headphone acting weird as hell. The battery drains quickly even if you wont use it. Say it like 100 to 0 in around 3 hours of non usage ( As like you, the bullets magnet attached ) . You need to charge them completely. Even during charge, the red light wont turn off after full charge. With these issues continuing for almost a month, now the bullets acts like - during charge the red light blinks and sometimes the red light wont show up. You wont believe the battery life - STUNNING DRAINS WITHIN 1 HOUR FROM 100% - 0% IF YOU CHARGE THEM FOR 10 MINS. Completely Irritated !
    Anilkumar.Dctr likes this.
  18. Anilkumar.Dctr
    Donut Jul 28, 2020
    Anilkumar.Dctr , Jul 28, 2020 :
    what could be the possibile solution to this problem?? I tried contacting the customer care but nobody answered the call even after waiting for half an hour on line.
  19. Anilkumar.Dctr
    Donut Jul 28, 2020
  20. X1513269271896
    Cupcake Jul 30, 2020
    X1513269271896 , Jul 30, 2020 :
    I have been using these headphones for about 2 weeks now. Initially I was facing the same issue, battery was draining very quickly. But now I tried draining the battery completely and fully charged the headphones (till the red LED turns white). with the 5T's 20watt charger, it took about 45 MINUTES to charge. Now after 2 days ( approx 12hours of usage) it's still showing 100%
