7
ONEPLUS BULLETS WIRELESS Z battery issue
  1. Anilkumar.Dctr
    Eclair Jul 31, 2020
    Anilkumar.Dctr , Jul 31, 2020 :
    I'll try that... hope that work for me too...
  2. Anilkumar.Dctr
    Eclair Jul 31, 2020
    Red LED not turning white... it's been more than three hours,I'm charging headphones with OP7T 30W charger. LED is still red. Any else facing this problem??
  3. A1590051468820
    Cupcake Aug 15, 2020
    A1590051468820 , Aug 15, 2020 :
    Can somebody give a solution for resolving quick battery drainage of OnePlus wireless z... I charged them over an hr last night but neither did the LED turned white nor did it gave backup of 20hrs... The battery died within 18hrs of minimal usage..I charged them the charger of realme X2 which supports warp charging
  4. A1590051468820
    I am also facing the same issue...please let me know if you get some resolution
  5. Anilkumar.Dctr
    Eclair Aug 15, 2020
    Anilkumar.Dctr , Aug 15, 2020 :
    I have sent the headphones to the op service centre,after talking with customer care. They said they will check headphones and if any problem found,they will replace the headphones.
  6. Anilkumar.Dctr
    Eclair Aug 15, 2020
  7. #27
  8. Anilkumar.Dctr
    Eclair Sep 4, 2020
    Anilkumar.Dctr , Sep 4, 2020 :
    got reply from service centre... we have checked the headphones and it's working fine,we are sending them back as it is.
    yesterday I got headphones,still there is problem with battery. At night it was 30% and in morning totally dead. only 4-5 hour of back up. I wonder did they really checked the headphones or jus sent back like that only. Really disappointed by the op service centre.
  9. vsc1242
    Donut Oct 30, 2020
    vsc1242 , via OnePlus 7T , Oct 30, 2020 :
    Red LED not turning white... it's been more than 1 hour, I'm charging headphones with OP7T 30W charger. LED is still red. what's the solution for this? or the headphones are faulty?
    amit_9638 likes this.
  10. amit_9638
    Cupcake Oct 31, 2020
    amit_9638 , Oct 31, 2020 :
    Same here but i found a workaround-> first charge it for 35 min then disconnect the charger, connect again and wait till 10 mins then the led will turn white. It's so annoying.
    vsc1242 likes this.
  11. vsc1242
    Donut Nov 1, 2020
    vsc1242 , via OnePlus 7T , Nov 1, 2020 :
    thanks, will try and check.
  12. [email protected] , via OnePlus 8 , Dec 8, 2020 :
    Hey i bought a new OnePlus Bullets wireless z earphone yesterday and took around 52 mins to full charge it...but u have said it takes only 23 mins to full charge? What shall i do
  13. I1609382377636
    Cupcake Dec 31, 2020
  14. G1557432990258
    Cupcake Oct 19, 2021
    G1557432990258 , Oct 19, 2021 :
    1 year completed of my one plus bullet z neckband and since 15 day's i am facing battery draining as fast as only 15 to 30 min. Please suggest me something.
