OnePlus Bullets Wireless Z - Quick Review via OnePlus 6
  1. Elatchian Veeramani
    Honeycomb Jun 12, 2020
    Elatchian Veeramani , via OnePlus 6 , Jun 12, 2020 :
    My Op Device: OnePlus 6 - 8GbRam Variant
    BWZ Purchased on : 02/06/2020
    Review after 10 Days of Usage :
    1.Usage: I Would Say BWZ was preferably made for Op devices especially from Op7 series. The reason behind that was The difference b/w HD AAC and Dolby Atmos* which is supported from op 7+ series only. That will give u the Exact Sound Tune and Quality they made using Single 9.12mm driver.
    2. Connectivity: Tooks 2-3 secs for me to pair with my Op6.
    3. Sound Quality: Average. I would say Clarity is there but not the quality. Don't expect More for this price Range.
    4. Buttons: Quite sticky. Doesn't felt that click.
    5. Battery Backup: Same as expected the battery backup is excellent. But I would like to note a point: BWZ Battery Consumption is directly proportional to the Distance of the BWZ from mobile. If u are at the verge of 10-12 mtrs surely battery will last within 2-3hrs from 100% charge. I have tested this twice.
    6. Design and Make : Excellent Design. Cables are smooth and Strong.
    7. Charging: As scripted 10 mins of charge will surely give u 10hrs of backup. it took 30 mins to fully charge using my Op6 dash charger.
    K Hemanth Kumar likes this.
  2. K Hemanth Kumar
    Eclair Jun 16, 2020
  3. Elatchian Veeramani
    Honeycomb Jun 24, 2020
  4. SameerG25
    Cupcake Jun 28, 2020
  5. Elatchian Veeramani
    Honeycomb Sep 6, 2020
    Elatchian Veeramani , via OnePlus 6 , Sep 6, 2020 :
    I already mentioned about the sound quality. Its crystal clear but quality of bass is under average
