Oneplus fingerprint problem via OnePlus 7
  1. KishanGarach
    Cupcake Aug 26, 2020
  2. dikoscilator
    Honeycomb Aug 28, 2020
    dikoscilator , via OnePlus 7 , Aug 28, 2020 :
    Try resetting your finger print
    This often happens when your thumb or your finger develops cuts or bruises from working or the other problem is when you don't use your dominant hand to open so the accuracy of the fingerprint decreases you have to use it consistently for it to improve the unlocking speed
    KishanGarach likes this.
  3. KishanGarach
    Cupcake Aug 28, 2020
    KishanGarach , via OnePlus 7 , Aug 28, 2020 :
    No bro after 7 time going customer care after solved this problem
  4. dikoscilator
