Other OnePlus Launcher keeps stopping
  1. hazacs
    Cupcake Sep 8, 2019
    hazacs , Sep 8, 2019 :
    Hi,
    I've been using Onelus 3T for almost 2.5 years now. Now I'm facing a serious issue which is not letting me use anything n my phone. There's nothing visible on the home screen. When I swipe down for notification panel, only first six options are available i.e. wi-fi, mobile data, Hotspot, Bluetooth, location and screen orientation. I can't work with any one of these, they'Are just clickable so that I can turn them on or off - that's it. I'm also not able to open phone settings from the notification panel.
    When I open the apps menu, after almost 2-3 seconds, it says OnePlus Launcher keeps stopping and the menu closes. But before these 2-3 seconds, if I quickly tries to open an app from the menu, then the app is opened and it works fine. But overall, I'm not able to use my phone.
    Does anyone know solution to this problem? I don't want to factory reset my phone.
    Any kind of help is really appreciated.
    Thanks
  2. P1569002692048
    Cupcake Sep 20, 2019
    P1569002692048 , Sep 20, 2019 :
    I have the same issue that just happen today. Looking at some suggestions from other having same issue, I un-installed the OnePlus Launcher updates and at least I have access to my apps when I pull them from the bottom. However, all my apps shortcuts on the screens I've created are missing and it does not allow me to create a shortcut at all now. Frustrating :-(
  3. smitha photos
    Eclair Sep 22, 2019
  4. abinashdash2009
    Cupcake Apr 5, 2020
    abinashdash2009 , via OnePlus 3T , Apr 5, 2020 :
    hi how did you fix it..??
  5. H1612193407730
    Cupcake Feb 2, 2021
    H1612193407730 , via OnePlus 3T , Feb 2, 2021 :
    When you get the notification that the app keeps stopping, click on app info and then it takes you to the app settings. On the top right click uninstall updates and then you are left with the factory version. I have been using it like that for 10 or so months
