4
OnePlus Nord 2 missing VoLTE and VoWiFi
  1. Maroof_KHAN , via OnePlus Community App , Aug 13, 2021 :
    Oh ok..! I'm talking about India. Don't know about other regions.! Well thanks 😊
  2. maxik
    Honeycomb Aug 13, 2021
    maxik , Aug 13, 2021 :
    Yep, that's it. An italian Youtuber flashed the modified files to Qualcomm powered One Plus phones. After this he had 5g connectivity
    I'll hope they do so....
  3. #23
  4. E1626847688757
    Cupcake Aug 24, 2021
  5. J1629918355765
    Cupcake Aug 29, 2021
    MANinWHITE and camhef like this.
  6. andrea7376
    Cupcake Aug 31, 2021
  7. Wonder
    Cupcake Sep 1, 2021
    Wonder , Sep 1, 2021 :
    Same problem.
    I have a sim Vodafone Spain, in OnePlus Nord work and appears VoLTE.
    Change the sim to my new OnePlus Nord 2, not appear any about VoLTE Vo-Wifi...and I can select the icon for appear VoLTE (in task bar) in section of select whats icons appears.
    But in settings, any about VoLTE for enabled this...I can't and in OnePlus Nord yes but not in Nord 2.
  8. Wonder
    Cupcake Sep 8, 2021
  9. AGM59
    Eclair Sep 9, 2021
    AGM59 , via OnePlus Nord 2 , Sep 9, 2021 :
    VoLTE and VoWiFi don't work with MTS provider (Russia, Moscow).
    VoLTE and VoWiFi options are lacking in the SIM settings.
    OS V11.3 Model DN2103
    My SIM on other smartphone (Huawei Honor 9) supports both VoLTE and VoWiFi
    MANinWHITE likes this.
  10. Wonder
    Cupcake Sep 9, 2021
    Wonder , Sep 9, 2021 :
    In my case (I don't know if I put it in the other thread or in the feedback / bug) I did the following test:
    I made a call outside my home, where there is good 5G and / or 4G coverage, during the call, I surfed the internet and did a speed test. My internet connectivity was perfect and the 5G icon did not change.
    That means that VoLTE is working (if not, it would have changed to 3G) but the option to activate or deactivate VoLTE is not in settings and the VoLTE status icon does not exist either.
    This in the Nord1 exist.
    Take that test, make a call and try surfing the internet. If you browse well and the network icon does not change, you have VoLTE operational, although you do not select the option in settings or in the status icon.
  11. AGM59
    Eclair Sep 9, 2021
    Wonder likes this.
  12. Wonder
    Cupcake Sep 9, 2021
    Perfect! I wait your report :)
  13. AGM59
    Eclair Sep 13, 2021
    AGM59 , via OnePlus Nord 2 , Sep 13, 2021 :
    My report is very short. VoLTE is not supported by my Nord 2 in the MTS network in Moscow. After I make a call data transfer immediately switches from 4G to 3G or H+. I made measurements by OOKLA Speedtest out of curiosity. 4G is 5 times faster than 3G during phone conversation.
  14. Wonder
    Cupcake Sep 13, 2021
    Wonder , Sep 13, 2021 :
    Yes, if in call swtich inmmediately from 4G to 3G or H+, then, not are in VoLTE / not supported...
    If VoLTE work, in the call, continue your status icon in 4G, not change to 3G or H+...
  15. AGM59
    Eclair Sep 13, 2021
    Yes. Thank you. I understand. But my current 4-years old Huawei Honor 9 works in VoLTE and VoWiFi with the same SIM-card which I am re-inserting from one phone to another. And provider's internet settings are identical in both phones. I've compared.
    J1629918355765 likes this.
  16. Wonder
    Wonder , via OnePlus Nord 2 , Sep 13, 2021 :
    In this case, Nord 2 with your operator, is not compatible with VoLTE....
    You can ask to OnePlus support if it's compatible, but I think that not...
  17. AGM59
    Eclair Sep 14, 2021
    AGM59 , via OnePlus Nord 2 , Sep 14, 2021 :
    How can I contact 1+ support? Because it seems to me that the problem is not in hardware, but in software. In some inner settings that are not available or unknown to us - ordinary users. Above I can see a message by another MTS Russia user from a different part of the country. He doesn't have VoLTE too. Maybe 1+ later will correct something in the upcoming firmware update and activate support by this operator. The more we complain the more chances that the problem will be improved.
    #38
  18. G1631734033243
    Cupcake Sep 20, 2021
    G1631734033243 , Sep 20, 2021 :
    Все точно так же. Только оператор Мегафон. Россия. Надеюсь на быстрое исправление.
    #39
    G1632750768473 and AGM59 like this.
  19. R1631848433063
    Cupcake Sep 21, 2021
    R1631848433063 , Sep 21, 2021 :
    Hello there! No VoLTE and VoWiFi options on Nord 2! (Russia, MTS provider)
    These options worked well on my Huawei Mate 20, with the same SIM!
    Hope Oneplus will fix that.
    #40
    camhef likes this.
