57
Working OnePlus nord battery drain
  1. R1598623869478
    Cupcake Sep 17, 2020
  2. devchr54
    Donut Sep 17, 2020
    palak7695 likes this.
  3. i.Arvind_kumar
  4. F1599205882544
    Honeycomb Sep 17, 2020
    F1599205882544 , via OnePlus Nord , Sep 17, 2020 :
    Hi,
    your battery is normal and not draining fast. You are too impatient and as every impatient persons you read and relay a wrong information.
    First of all you must use a lot of apps during hours and hours. You'll see that the battery time will increase more and more from 5-6 hours to 1 or 2 days (sometimes more) . Let the phone study your daily apps and datas uses and the statistics will be more and more reliable day after day. Without such an analyse the smartphone guesses absolutely nothing !
  5. Shoaib_Khan79
    Cupcake Sep 18, 2020
  6. X1596780762620
    Eclair Sep 18, 2020
  7. W1597732148143
    Cupcake Sep 19, 2020
  8. F1599205882544
    Honeycomb Sep 19, 2020
    F1599205882544 , via OnePlus Nord , Sep 19, 2020 :
    Hi
    In this concert of critics on the battery drain of the OnePlus Nord, it is time to restore a bit of balance.
    I have OxygenOS 10.5.7 and a standard use of the Nord all day long.
    On my Nord 12GB/256GB my Wifi, Bluetooth, position are always on. In parameters I have something like 155 apps or modules running or not.
    At night with locked device the battery drain is more or less 3% every 6 hours which seems a normal value.
    At the end of each day my remaining energy is around 40 to 60%.
    I always look at the statistics after a half day because if not the system cannot analyse my daily uses.
    Finally my battery lasts from 1 to 2 days or a bit more which is very honorable and sufficient for such a powerful device.
  9. F1599205882544
    Hi
    Absolutely no reason to panic... There is no issue at all ! If you count 3% every 6 hours which is normal on many devices the battery can last 1 week in standby ! And one or 2 days in normal use.
    Abhishek1506ty likes this.
  10. Mayur Ahir
  11. nitin9989
    Cupcake Sep 25, 2020
  12. RanjanNitish
    Cupcake Oct 2, 2020
    RanjanNitish , Oct 2, 2020 :
    Battery drains like a downhill while hotspot is on. Very disappointed with this draining issue. Hoping that this issue will be taken care of ASAP.
