9
OnePlus Nord frequent browsing failure due to no network via OnePlus Nord
  1. #1
  2. B_Wrath
    Junior Moderator Junior Moderator Aug 17, 2020
    B_Wrath , Aug 17, 2020 :
    Does it happen only in the Google app?
    And your signal seems pretty poor. Does the loading fail when you have full signal too?
    Caoimhín likes this.
  3. #3
  4. Ruqhaiya Taskeen
    Ice Cream Sandwich Staff Member Aug 17, 2020
    Ruqhaiya Taskeen , Aug 17, 2020 :
    Thanks for bringing this concern to our notice.We would like to check this further and require more details regarding this. We've got in touch with you via personal conversation and hope you would get back to us at the earliest.
    Regards,
    Ruqhaiya Taskeen
  5. Amanmishra55
    Cupcake Aug 17, 2020
    Amanmishra55 , via OnePlus Nord , Aug 17, 2020 :
    I am also facing the same issue , even of the network is full it occurs frequently . I also reported it to OnePlus but I got no solution . Do you found any solution
  6. LuckyYelgate
    Cupcake Aug 18, 2020
  7. G1577192443231
    wojciech.kudla likes this.
  8. Caomhin
    9 Series Expert, Participator of the Year Community Expert Aug 18, 2020
    Caomhin , via OnePlus 6T , Aug 18, 2020 :
    Reset the Network Adapters.
    Settings, System, Reset Options, Reset WiFi Mobile Bluetooth.
    For WiFi issues also check the links below.
    How To Fix Common Wi-Fi Problems In Android
    https://www.techjunkie.com/fix-wi-fi-problem-android/
    Also a suggestion here for 8 Series but some of the suggestions may crossover to other OnePlus phones .
    https://forums.oneplus.com/threads/my-findings-of-the-5-ghz-wifi-connection-issue.1221263/
  9. I1597659644256
  10. Caomhin
    Check the post above yours for WiFi suggestions that may help.
  11. bhanuprakashredd
    bhanuprakashredd , Aug 18, 2020 :
    Even I have the same problem.Though my signal is full but I cannot access internet.I also tried by keeping the same sim in another mobile and the internet is very fast in that mobile as compared to OnePlus nord.Please sort this problem ASAP due to this I'm facing alot of problems.
    U1599586158028 likes this.
  12. G1597781991404
  13. #13
  14. chiefybob
    Donut Sep 9, 2020
  15. W1598594074317
    Donut Sep 10, 2020
    W1598594074317 , Sep 10, 2020 :
    Absolutely shameless.
    Every single user is suffering from this problem. Yet OnePlus will come up with every excuse not to fix this issue.
    Has anyone used the chat customer service? Seriously words can not describe how dumb and incompetent oneplus staff are. I thought it was just one person but it's all of them
    Pranay datta likes this.
  16. Caomhin
    9 Series Expert, Participator of the Year Community Expert Sep 10, 2020
    Caomhin , via OnePlus 6T , Sep 10, 2020 :
    It's a Mobile Network issue in India and nearby locations, its not an issue in Europe.
  17. Jeffreyk97
    Eclair Sep 10, 2020
    Jeffreyk97 , via OnePlus Nord , Sep 10, 2020 :
    It happens in Europe as well. I live in the Netherlands and mobile network is not working correctly on my Nord either.
    chiefybob likes this.
  18. W1598594074317
    Donut Sep 11, 2020
    W1598594074317 , Sep 11, 2020 :
    Can't believe after all these complaints that OnePlus are so incompetent and dumb not to fix this. I knew I should have got the new Google phone. Return processed good riddance OnePlus. It's definitely not been fun
    wojciech.kudla and Pranay datta like this.
  19. pankajBahai
    Cupcake Sep 11, 2020
  20. P1599677946186
    Eclair Sep 11, 2020
    P1599677946186 , Sep 11, 2020 :
    Guys, Check this out.You will face wi-fi connectivity issue too.Just replicate the scenario i am describing.Choose Jiofi router, connect Oneplus Nord, another any smartphone and any laptop under same Jiofi router. All will work fine till now, then just disconnect laptop wifi. You will notice the other smartphone wifi still works fine but Oneplus Nord wifi will be unstable now, it will connect with wifi and will disconnect within a second, and this connect-disconnect will happen infinite times. Now if you connect the laptop wifi again, you will notice the wifi in Oneplus Nord automatically becomes stable again. Again you disconnect the laptop wifi, again you will see the issue. You may not notice the issue in single try, try at least 4 times and I am sure u will find the issue. To observe this a laptop connection is must. Where as u will see the other smartphone wifi works smoothly under same Jiofi. This only solves when u reboot the Jiofi. Now Nord wifi works fine until u connect any laptop to same jiofi again and observe the same issue again. Doing on/off wifi in Nord, reseting network in Nord, rebooting Nord, chaning settings to keep always wifi On, does not solve the issue. This is a genuine issue bcoz I observed the same issue with two different Nord phone, that means it exists in many Nord phone. I am chasing this with Oneplus support in Twitter, but the bother little to reply back and solve the issue!!
