9
OnePlus Nord frequent browsing failure due to no network
  1. hasanmk2k
    Cupcake Sep 11, 2020
    hasanmk2k , Sep 11, 2020 :
    I'm facing the same issue while using mobile data.
    It says no internet connection even with well working connection
  2. Caomhin
    OnePlus 9 Series Expert Community Expert Sep 11, 2020
    Caomhin , via OnePlus 6T , Sep 11, 2020 :
    Sounds like an issue with the Jio WiFi router.
  3. P1599677946186
    Eclair Sep 12, 2020
    P1599677946186 , Sep 12, 2020 :
    Let me tell you, from lock down (i.e., March 2020) I am using same JioFi and I was using my laptop and Honor 9i phone same way all the time. I have not faced the issue single time. Again to test out more, I checked with Realme 2 pro and Asus m2 max pro and Oppo f1s. I never faced the issue for single time with any of the other smartphone. So request you to check the scenario from ur end like i described (if there is a possibility). I am almost sure I will face the issue too. And do let me know ur test results. I have also recorded the video to show when Nord wifi is fluctuating, at the same time just beside Nord, the Asus phone wifi works fine under the same JioFi router under the same situation. Nord wifi fluctuates every time where as Asus wifi works perfectly every time
  4. Caomhin
    OnePlus 9 Series Expert Community Expert Sep 12, 2020
    Caomhin , via OnePlus 6T , Sep 12, 2020 :
    Report the issue directly to OnePlus Developers as a Bug report.
    And also contact OnePlus support directly to see if they have more information on your issue. Scroll down the page for contact and online chat details.
    P1599677946186 likes this.
  5. P1599677946186
    Eclair Sep 13, 2020
    P1599677946186 , Sep 13, 2020 :
    Thanks for your suggestions. Sure, i will do accordingly. Just curious to know whether it is software issue or hardware issue? If i have any suggestions...
  6. Caomhin
    OnePlus 9 Series Expert Community Expert Sep 13, 2020
    Caomhin , via OnePlus 6T , Sep 13, 2020 :
    It's impossible to tell without physically checking. You could also bring it to an approved OnePlus service center and see if they can check it out.
  7. piratey2k6
    Froyo Sep 13, 2020
    wojciech.kudla likes this.
  8. chiefybob
    Donut Sep 24, 2020
    chiefybob , via OnePlus Nord , Sep 24, 2020 :
    What slot is your sim in I had same problem so on chat to OnePlus for an hour ended up with me starting an RMA so when finding my IMEI no I noticed my sim was in slot two changed it and no problems so far
  9. Jeffreyk97
    Eclair Sep 24, 2020
    chiefybob likes this.
  10. chiefybob
    Donut Sep 24, 2020
    Sorry it seams to have fixed mine thought I would put it out there mine will probably be sent to them on RMA in a week when it hasn't worked there maybe something in the sim tray maybe try as I said when I got the phone usual thought I know everything and just shoved the sim in and never noticed it had a slot both sides
    Jeffreyk97 likes this.
  11. K1597492426627
    Donut Sep 25, 2020
    K1597492426627 , via OnePlus Nord , Sep 25, 2020 :
    there is a big network issue in nord..whenever I Google anything it says offline even the data is on...as u give reload it loads with ease.. donno whats the pblm with nord...and while playing pubg u get connection lost message and u have to re enter match again...if it happens when there r enemies in front they u knw wt happens....
    next CODM ...same pblm ... connection lost ...and here to reconnect u should turn on airplane mode and off it again...
    next Among us ...u can't play among us in nord ..don't even dare to because u will be the only one walking around and others will be standing still....and it does not have a option of reconnecting ...so u can't play among us ...30000 gone in vain..
    plz OnePlus team this is a major issue plz solve this with update or if it's hardware plz fix it in your store plz ...
    I hope u will consider....
    ss of Google pblm
    piratey2k6 likes this.
  12. piratey2k6
    Froyo Sep 25, 2020
    piratey2k6 , via OnePlus Nord , Sep 25, 2020 :
    OnePlus team isn't doing anything to fix this issue. Majority of ppl are facing it and it's been almost two months since Nord release. plz fix this major issue
  13. Caomhin
    OnePlus 9 Series Expert Community Expert Sep 25, 2020
    Caomhin , via OnePlus 6T , Sep 25, 2020 :
  14. skilic
    Cupcake Oct 5, 2020
  15. chiefybob
    Donut Oct 5, 2020
  16. I1586609799668
    Cupcake Oct 19, 2020
    LucaS5 likes this.
  17. LucaS5
    LucaS5 , Oct 19, 2020 :
    This is my first oneplus. I think it will also be the last. 400 € for a phone that immediately gives problems. I do nothing with the community if the device from birth has software or hardware problems.
  18. Q1604694274107
    Cupcake Nov 6, 2020
    Q1604694274107 , Nov 6, 2020 :
    I have the same problem, cant start homepage on google, when using mobileconnection.
    I live in Denmark, Europe.
    Works sometimes to go back and search the same homepage again, and IT Will Work
    #38
  19. dandju
    Cupcake Dec 1, 2020
    dandju , Dec 1, 2020 :
    Having the same issue.
    It loses connectivity and people can't reach me - so it's not just the internet which is gone, it's completely the phone signal ...
    @OnePlus - What are you going to to about that?
    #39
  20. LucaS5
    Cupcake Dec 29, 2020
    #40
