32
OnePlus Nord Green Tint Display Issue
  1. Does!Compute
    KitKat Jul 31, 2020
    Does!Compute , Jul 31, 2020 :
    Can you please share the link for this on twitter? Haven't found it on twitter yet.
    #41
    Amanda W. and Starcommander like this.
  2. MrTechAuditor
    Honeycomb Jul 31, 2020
    #42
  3. Does!Compute
    KitKat Jul 31, 2020
    #43
    MrTechAuditor and tirthak_modi like this.
  4. steveeeg
    Froyo Aug 1, 2020
    steveeeg , Aug 1, 2020 :
    Just ordered my first OnePlus phone the nord , this is very concerning might well cancel order now , shame as was looking forward to it
    #44
    tirthak_modi likes this.
  5. G1586854699500
    Cupcake Aug 1, 2020
    G1586854699500 , Aug 1, 2020 :
    I had pre booked Nord..But i am now very tensed...whether to buy or cancel..will the display problem get resolved?
    #45
  6. Shubhangi.Misra
    Cupcake Aug 1, 2020
    Shubhangi.Misra , Aug 1, 2020 :
    Hey
    This seems quite comprehensive but I beg to differ.
    As per Oneplus, the refresh rate is hardware accelerated that is they have used a capacitor ( included with the thin film transistor used in the Flat panelled AM- OLEDs) and this is causing the decolourisation at low brightness and this more likely in screens with the higher refresh rate. I have known this issue since Oneplus 7T and they haven't come up with any fix yet for that. However, Oneplus can surely try what you suggested but the only problem is the high refresh rate is not unlocked by their software!
    It is a hardware issue unfortunately either a replacement or a refund is the only option
    #46
  7. ilpolpi65
    Honeycomb Aug 1, 2020
    ilpolpi65 , via OnePlus Nord , Aug 1, 2020 :
    My display is perfect like a lot of others people's displays.
    Paolo
    #47
  8. Gigimouse81
    Eclair Aug 1, 2020
  9. karkyaal , via OnePlus Nord Gray Onyx , Aug 1, 2020 :
    checked mine today as well.. there is slight green tint towards the upper and right side and purple towards bottom. so far i had not noticed it. so is this a big issue ? i also read that oled panel seems to have some tinting. if this is a big tinting then i might have to think to return the device.
    any one for some thought on level of tinting here?
    #49
  10. karkyaal , via OnePlus Nord Gray Onyx , Aug 1, 2020 :
    mine also have some tinting.
    #50
  11. OPD
    Gingerbread Aug 1, 2020
    OPD , Aug 1, 2020 :
    Is that photo yours?
    #51
  12. #52
  13. OPD
    OPD , Aug 1, 2020 :
    For me that's too much, but it really depends on your tolerance to the tinting.
    #53
  14. Mat_Thieu
    Mat_Thieu , Aug 1, 2020 :
    It is like my device, you can compare my photo in the first post. I have 3 Oled devices and only the OP Nord has this tint issue. It is too much to be an general oled issue. My device will be replaced. If the second device still have the same issue I will ask a refund
    #54
  15. karkyaal , via OnePlus Nord Gray Onyx , Aug 1, 2020 :
    till now i had not noticed it. i just was checking it today in a dark room and i really had to look for it 😀 but in normal use i have no issue with the display . so i am bit confused about it and they have said an OTA update on the way. lets see if this will be fixed for others as well.
    #55
  16. karkyaal , via OnePlus Nord Gray Onyx , Aug 1, 2020 :
    yes it is similar to yours. lets see if the update will not fix it then i might return the device ..need to get think a bit more on this .
    cheers!!
    #56
  17. MrTechAuditor
    MrTechAuditor , via OnePlus 7 Pro , Aug 1, 2020 :
    Hey Shubhangi
    I got your point, but the suggestion is not mine.
    @Arjun Choudhry suggested it to a community user, and I saw the screenshot in a Twitter post
    #57
  18. r_wind
    Cupcake Aug 1, 2020
    r_wind , Aug 1, 2020 :
    I'm also confuse should I cancel my order?
    #58
  19. Mat_Thieu
    Mat_Thieu , via OnePlus 8 Pro , Aug 1, 2020 :
    You only have 15 days to replace your phone. So don't wait too much...
    #59
  20. karkyaal , via OnePlus Nord Gray Onyx , Aug 1, 2020 :
    yes. .. i am still thinking about it . as I mentioned i really had to look for it, otherwise there is no issue with display in normal day to day use .do you think this will be a big issue in longer run ? i have emailed the support. let's see what they have to say.
    cheers!
    #60
    jason.sundaram likes this.
