6
OnePlus Nord not Warp Charging
  1. vcvasanth
    Cupcake Aug 15, 2020
    #41
  2. P1595994414694
    Cupcake Aug 18, 2020
    P1595994414694 , Aug 18, 2020 :
    I am also facing the same issue...it was working just fine and suddenly a day back its not warp charging.My device is charging at rate of just 25 percent in half an hour even after switching off charging optimization.Anyone please help me with this.
    #42
    Karan Joseph likes this.
  3. W1597218425267
    Donut Aug 18, 2020
    #43
  4. W1597218425267
    Donut Aug 18, 2020
    W1597218425267 , via OnePlus Nord , Aug 18, 2020 :
    That's mine Nord! There is no way of giving optimization option that we need to turn on/off. This means OnePlus faking by marketing 30w warp charge. Whereas while turning this option on, will get u back to basis charging speed.
    #44
  5. Karan Joseph
    Eclair Aug 22, 2020
    Karan Joseph , via OnePlus Nord , Aug 22, 2020 :
    It's been a few days since I shared the logs and the requested information. No update yet. Phone hasn't been warp charging ever since I bought it. Been about 18 days. Will there be an update or soemthing to fix this?
    #45
  6. W1597218425267
    Donut Aug 22, 2020
    #46
  7. X1596551293381
    Cupcake Aug 25, 2020
    X1596551293381 , Aug 25, 2020 :
    This worked for me, thanks!
    #47
  8. nurulgofran
    Cupcake Aug 26, 2020
    nurulgofran , Aug 26, 2020 :
    Sometimes it charges fast Sometimes very slowly like 10 watt charge. I don’t know the problem
    #48
  9. Naveen.2002
    Cupcake Aug 27, 2020
    Naveen.2002 , via OnePlus Nord , Aug 27, 2020 :
    I am facing some different charging regards this.
    I am charging the phone with the 30T warp charger and the same cable given in the box.
    But in the charging circle it is not showing warp charging.
    give me the information regarding this.
    #49
  10. Naveen.2002
    #50
  11. #51
  12. _pixl_ , via OnePlus Nord Gray Onyx , Sep 2, 2020 :
    I ran into a similar issue. I was using my 150cm flat wire bought 2 years earlier with my warp charger. It drawed about 1.8 amps. Changed that with the stock wire and back at 4.5-5Amps.
    #52
  13. W1597218425267 , via OnePlus Nord , Sep 2, 2020 :
    bro i am using the same cable that i got in nord box
    #53
  14. _pixl_ , via OnePlus Nord Gray Onyx , Sep 2, 2020 :
    I would suggest using a different wire with your adapter as well as your wire with a different adapter.
    This can help you diagnose where the problem is at.
    Sometimes a portion of inside fibres get damaged in a cable and it draws less amps( faced this too).
    If your adapter and wire is fine, i would wait for ota 10.5.6(1-2 days) and if that still doesn't fix your issue, you will have to go a repair center.
    #54
  15. _pixl_ , via OnePlus Nord Gray Onyx , Sep 2, 2020 :
    One more thing to add is, in your screenshot your battery temp is at 42 degrees. Amps are also adjusted according to the heat in your battery. In my case my temp remains around 37 degrees, so this might be a potential issue.
    #55
  16. RajGoswami
    Cupcake Sep 2, 2020
    #56
  17. Ronak__Shah
    Cupcake Sep 4, 2020
    #57
  18. P1599224324625
    Cupcake Sep 4, 2020
    P1599224324625 , Sep 4, 2020 :
    Hi, I just bought oneplus nord 8 gb yesterday, and the device isn't taking warp charge at all. I'm sure of it as it's just showing "charging" message on the lock screen instead of " warp charge" and is taking 2 + hours to charge fully.
    Please give me a solution.
    #58
  19. Q1597656622671
    Cupcake Sep 5, 2020
    Q1597656622671 , via OnePlus Nord , Sep 5, 2020 :
    hello @OnePlus
    My one plus nord is not showing waro charging when it is being charged, this has been happening since a few days now. Overall, the charging rate is being very slow, as compared to some weeks back, when it was getting warp charged. please see to it at the latest.
    #59
  20. RajGoswami
    Cupcake Sep 5, 2020
    #60
