6
OnePlus Nord not Warp Charging
  1. #61
  2. AkkuAshish
    Cupcake Sep 5, 2020
    AkkuAshish , via OnePlus Nord , Sep 5, 2020 :
    I am also facing the same problem .today I charged my phone 2 time , morning it took 1hr 10 mins to chrg from 20 to 96 and evng it took 36 mins to chrg from 36 to 95 it was okkey
    But the problem is that this phone some times warp and sometimes doesn't. Sometimes it's normally chrg nd am facing issue
    #62
  3. S1597299054191
    Cupcake Sep 8, 2020
    S1597299054191 , via OnePlus Nord , Sep 8, 2020 :
    I have the same issue with warp charging , at the time of charging it shows warp charging but then after sometime it shows as normal charging. please help me with this.
    #63
  4. Shefuda
    Cupcake Sep 14, 2020
    Shefuda , Sep 14, 2020 :
    i am having the same problem, it shows that its warp charging but it take 1 hour or longer to fully charge, also it shows 1800 mah with or without battery optimization
    #64
  5. josef127
    Froyo Sep 14, 2020
    #65
  6. josef127
    Froyo Sep 14, 2020
    josef127 , via OnePlus Nord , Sep 14, 2020 :
    you don't have a problem. If the battery is hot enough it will not warp charge. Anything above or equal to 40 degrees celsius it will not charge. Maybe even 39 degrees too
    Stop complaining people
    #66
  7. josef127
    Froyo Sep 14, 2020
    You don't have an issue. If the battery is hot it will not warp charge. Enough writing nonsense
    #67
  8. josef127
    Froyo Sep 14, 2020
    #68
  9. Rohit2230
    Cupcake Sep 15, 2020
    Rohit2230 , Sep 15, 2020 :
    Hi Ruqhaiya,
    I have recently bought OP Nord and I also have the same issue. When I connect OP 5 charger it shows fast charging symbol but not when I use OP Nord charger. Can you help me here?
    #69
  10. sahilgoyal786
    Froyo Oct 7, 2020
    sahilgoyal786 , Oct 7, 2020 :
    Exactly, my case, thanks a lot
    #70
  11. Man0jk
    Gingerbread Oct 8, 2020
    Man0jk , Oct 8, 2020 :
    Im also facing the same issue something's, hope they fix it in the next update.
    #71
