OnePlus One Bluetooth
  1. wilmarsaly
    Jelly Bean Dec 13, 2014
    wilmarsaly , Dec 13, 2014 :
    Yes, Bluetooth is great! Use it with Fitbit and Bluetooth audio reviewer, both reply good!
    #81
  2. reysbro
    Cupcake Dec 16, 2014
    reysbro , Dec 16, 2014 :
    OPO won't find Garmin Edge 810. Other Android devices do. Ideas? Thanks.
    [edit] NVM rebooted OPO and it works.
    #82
  3. Mina. Awad
    Eclair Dec 18, 2014
    Mina. Awad , Dec 18, 2014 :
    I am assuming opo has bluetooth HOD? I have the microsoft univeral keyboard it works fine with android nexus 7 but opo can never find it, does anyone have an idea whats wrong? I know the keyboard needs the HID capability to work, i would think most blue tooth devices have that?
    Edit: nevermind it finally connected
    #83
  4. gyerram14
    Cupcake Dec 19, 2014
    gyerram14 , Dec 19, 2014 :
    so after unpairing my samsung level overs on my One Plus, the phone doesn't detect the headset anymore. I've tried restarting both devices several times, but to no avail. Is there anyway I can fix this? :/
    #84
  5. NCguy
    Froyo Dec 19, 2014
    NCguy , Dec 19, 2014 :
    Try, as a test, to see if you can pair the headset to a different phone. Sounds to me like the headset itself might have possibly failed.
    #85
  6. JeromeGrevin
    Cupcake Dec 31, 2014
    JeromeGrevin , Dec 31, 2014 :
    Does anyone try to connect his OPO with wireless Samsung Airtrack ? Any issue ? or any trick for having it works ?
    #86
  7. gyerram14
    Cupcake Jan 14, 2015
    gyerram14 , Jan 14, 2015 :
    The headset was in fact not detected by neither my friend's phone nor my Macbook; would I have to request for a replacement?
    #87
  8. sungjinchoi01
    Honeycomb Jan 14, 2015
    sungjinchoi01 , Jan 14, 2015 :
    my opo does not connect to my car and headset on its own.
    I have to manually connect through the phone by detecting the headset or manually play music for my highlander to play songs... anyone else having this issue with their opo? my other phone N5 detect and connect to headset on its own but opo is failing to do such simple task on its own....
    #88
  9. mschmidt
    mschmidt , Jan 14, 2015 :
    My opo connects to my car just fine, but when playing music at high levels there is a definite noisy signal problem particularly at higher frequencies. Almost sounds like a crappy AM station. Anyone else notice this over BT? I haven't noticed it with my portable BT speaker or my Motorola BT headset. I even wiped the phone (in the process of rooting), then updated my cars software firmware. Still having the same problem. The car is a BMW X5 with HiFi sound system. I've never had this problem with any of our other phones in the car.
    #89
  10. RKandra
    Gingerbread Jan 14, 2015
    #90
  11. aleric
    Eclair Jan 14, 2015
    aleric , Jan 14, 2015 :
    With ford fiesta 2009 doesn't work well...often craps and disconnects...hope for better Bluetooth connection on CM12
    #91
  12. Jamesst20
    Jelly Bean Jan 14, 2015
    #92
  13. whoopisux
    Donut Feb 6, 2015
    whoopisux , Feb 6, 2015 :
    Hi....how about range of blue-tooth receiver? is it up to 10M?
    Anyone can help?
    Thanks
    #93
  14. Navneet Taparia
    Cupcake Feb 17, 2015
    Navneet Taparia , Feb 17, 2015 :
    I tried to connect my OPO with my laptop. But it is not connecting. It says that the drivers are not installed. How do I go on with it ?
    #94
  15. fazfactor
    Honeycomb Feb 17, 2015
    fazfactor , Feb 17, 2015 :
    Works fine my friend :D
    #95
  16. Mummilana
    Cupcake Feb 22, 2015
    Mummilana , Feb 22, 2015 :
    My opo, can't connect to any bluetooth device :(, just got myself some powerbeats2 wireless.. Opo can't event find headset, can be found on other devices but not my opo!? Any idea why? Thanks in advance
    #96
  17. Verdinj06
    Eclair Feb 22, 2015
    #97
  18. Mummilana
    Nvm, after restarting phone a few times it's finally found it.. Pretty annoying but it it remembers them now..
    #98
  19. tarekma
    Gingerbread Feb 22, 2015
    tarekma , Feb 22, 2015 :
    Well it was fine before the latest update, now can't connect with my car.
    #99
  20. Nervvvv
    Nervvvv , Feb 22, 2015 :
    Either in CM11 or CM12
    My OPO does not connect to my car automatically.
    I need to turn on and off the BT, and press connect many times (>10) in order to connect.
    It is really annoying since my Nexus 4 does not have any problem.
