Oneplus One body dimensions
  1. OneOver Zero
    Ice Cream Sandwich Apr 1, 2014
    OneOver Zero , Apr 1, 2014 :
    But the width can't be 74mm because Z1 has 73.9 mm and we were told that there would be a OPO under the Z1.
    #41
  2. fabripav
    Honeycomb Apr 1, 2014
    fabripav , Apr 1, 2014 :
    In the pic you can see the 1+1 edge below the z1
    #42
  3. Deactivated User
    Apr 1, 2014
    #43
  4. OneOver Zero
    In an interview was stated: „The OnePlus One has one of the best screen/front space ratios on the market.“ The best screen ratios are like this:
    So I assumed it should have at least 72%, otherwise it wouldn't be one of the phones with the best ratio. I just made some calulations and came to the conclusion that the phone height shouldn't be more than 147.2 mm. (The Xperia Z1 has a height of 144.4 mm, this would explain why they did't show the whole Xperia when teasing us.)
    Calculation:
    • We know from the lockscreen leak that screen raio is 16:9. So the viewable screen dimensions would be 121.8 x 68.5 mm.
    • So the surface area of the screen alone is 83,39 cm²
    • OnePlus One can't be wider that 73.9 mm since we were told that we „saw“ it under a Xperia Z1. So I assumed a minimuim witdh of 71.5 mm to hold the screen (that would be 1.5mm bezels at both sides) and a maximum width of 73.8 mm to fit under the Xperia Z1.
    If screen ratio is 75%:
    With an assumed width of 71.5 mm the resulting height would be 145.8 mm. (see note below)
    With an assumed width of 72.5 mm the resulting height would be 143.8 mm.
    With an assumed width of 73.0 mm the resulting height would be 142.8 mm.
    With an assumed width of 73.5 mm the resulting height would be 141.8 mm.
    With an assumed width of 73.8 mm the resulting height would be 141.2 mm.
    If screen ratio is 74%:
    With an assumed width of 71.5 mm the resulting height would be 147.0 mm. (see note below)
    With an assumed width of 72.5 mm the resulting height would be 144.9 mm.
    With an assumed width of 73.0 mm the resulting height would be 143.9 mm.
    With an assumed width of 73.5 mm the resulting height would be 143.0 mm.
    With an assumed width of 73.8 mm the resulting height would be 142.4 mm.
    If screen ratio is 73%:
    With an assumed width of 71.5 mm the resulting height would be 148.1 mm. (see note below)
    With an assumed width of 72.5 mm the resulting height would be 146.1 mm.
    With an assumed width of 73.0 mm the resulting height would be 145.1 mm.
    With an assumed width of 73.5 mm the resulting height would be 144.1 mm.
    With an assumed width of 73.8 mm the resulting height would be 143.5 mm.
    If screen ratio is 72%:
    With an assumed width of 71.5 mm the resulting height would be 149.3 mm. (see note below)
    With an assumed width of 72.5 mm the resulting height would be 147.2 mm.
    With an assumed width of 73.0 mm the resulting height would be 146.2 mm.
    With an assumed width of 73.5 mm the resulting height would be 145.2 mm.
    With an assumed width of 73.8 mm the resulting height would be 144.6 mm.
    Actually I can hardly believe that the assumed 71.5 mm phone width would be enough to hold the screen. As you can read here, the 5.5 inch WQHD display by JDI has full dimensions of 70.94 x 128.26 mm, since it has some borders itself. So there would only be 1.56mm left which would mean 0.78 mm on both sides to hold the screen!!! Is that possible? The 1080p display in the OnePlus One will also have some little borders. Does anybody know what could be the minimum width to hold such a screen with a viewable width of 68.5 mm and a real width of about 70.94 mm?
    So I assume screen ratio will be more like 72% or worse. Because if screen ratio would be 75% or better the OnePlus One would completely fit under a Xperia Z1 no matter what the width is and they could have shown it like that.
    As others have observed we can actually vaguely see the bezel of the OPO under the Z1. If we assume a width of 73.8 mm this translates to a height of 144.6 mm which would not fit under a Z1 which would explain the cut-off-teasing-picture.
    So I think I can claim with an anticipated success rate of about 72% that the dimensions of the OnePlus One will exactly be nearly 144.6 x 73.8 mm or something similar. Sure, all this depends on the assumption that they didn't show the whole Z1 because otherwise we could have seen a bit of the OnePlus One. What do you think?
    Kind regards,
    OneOver „Sherlock“ Zero
    #44
  5. Hige
    Jelly Bean Apr 1, 2014
    Hige , Apr 1, 2014 :
    really great comment and very detailed!
    I wish you're right although ;)
    #45
  6. fabripav
    Those are some impressive calculations! In the Reddit AMA they said the 1+1 will have a "slightly better body/screen ratio than Nexus 5". So I'd say we can expect a ratio of 73% or 74%.
    Couldn't the 1+1 be like one mm larger than the Z1, since we see its edge in the famous pic?
    #46
  7. mark
    Donut Apr 1, 2014
    #47
    leobg and stadienator like this.
  8. Deactivated User
    Apr 1, 2014
    #48
  9. OneOver Zero
    So that would mean 145.1 x 73.0 mm or 146.1 x 72.5 mm (with 73% ratio). Or 144.9 x 72.5 mm (74% ratio).
    Or: To get the OPO a bit longer that the Z1 we need to assume really small bezels at the sides: So 145.8 x 71.5 mm could also be possible from calculations. But then I wouldn't understand why we could see part of the OPO bezel under the Z1.
    Or you are right and the OPO is about 1 mm wider. But every mm we make the OPO wider means that the height is getting lower. That would mean that the OPO would completely fit under the Z1. So why did't they show us the whole Z1 with the OPO sitting under it?
    #49
  10. fabripav
    To make us speculate like this :p
    Anything is possible really, maybe they let the edge of the phone slightly out just to make us talk about it. Maybe it completely fits below the z1.
    What I hope is that we don't get incredibly thin side bezels with huge top and bottom ones. I'd rather have a balanced look.
    #50
    Adiyel, May I Taste and Chinda like this.
  11. Hige
    This really looks like find7..
    #51
  12. OneOver Zero
    Yeah, too small bezels are no fun. Because when operating one handed and I take my thumb to reach the top of the screen I often accidently touch the bottom of screen with part of the root of my thumb. Argh! And that's just a Galaxy S2.
    #52
    K25TM likes this.
  13. SoulTribunal
    SoulTribunal , Apr 1, 2014 :
    Thats some great work there, I did something like that a week ago, even drew up a model on sketchup to see how it could look. I came up with dimensions along the lines of ~146mm and 74mm but man if they can do it at 144.6 that would be great!
    It would still explain why we can't see the bottom on the photo, that extra 0.2mm ain't much but it might still be noticable and give away to much info :D
    #53
  14. alextdarling
    alextdarling , Apr 1, 2014 :
    someone mentioned about a 16:10 aspect ratio, I agree with this if there are on screen buttons, I know android has "Immersive mode" now but its still very limited, I believe, having the extra length enables the onscreen buttons without affecting real onscreen space.
    #54
    José Saldanha likes this.
  15. Nagasaky2x
    Nagasaky2x , Apr 1, 2014 :
    That should be fixed via software just like Apple does with thumbs on tablets.
    #55
  16. Joseph Wheeler
    Gingerbread Apr 1, 2014
    #56
  17. Chinda
    Chinda , Apr 1, 2014 :
    That concept was on chinese forums few weeks ago.
    #57
  18. Chinda
    Staff member of OnePlus said before that they wouldnt be using any weird aspect ratio for the screen.
    #58
  19. Nagasaky2x
    Well, 16:10 is not weird at all, that's my desktop resolution and most professionals use that.
    #59
  20. alextdarling
    The point I was making was that It wouldnt matter what the aspect ratio was as the onscreen buttons made up for it
    #60
