ONEPLUS One - Default Photo Edit tools gone - Help
  1. Solano
    Cupcake Aug 3, 2014
    Solano , Aug 3, 2014 :
    Hi community,
    when i received my opo i had some default installed photo edit tools onboard.
    they were great and the better as whats out there in the play store.
    i installed some other photo and photo edit tools, deinstalled them and now the default edit tools which came with the phone are gone too!!!
    can somebody tell me where i can get them?
    whats the name is at least.
    or maybe even upload them for me as apk if its even possible???
    i want them really back! they were great!
  2. jkbhso3
    Jelly Bean Aug 3, 2014
    jkbhso3 , Aug 3, 2014 :
    I has the same issue where they disappeared from menus and such for setting a wallpaper or trying to crop an image after disabling google+. Re-enabling google+ brought them back.
    Planoman likes this.
  3. OPToxic
    Honeycomb Aug 3, 2014
  4. Solano
    Cupcake Aug 3, 2014
    yeah! i disabled g+ somehow when i got the phone!
    can you tell me how to get it back?
    EDIT
    Dont mind i got it!
    and you were totally right!
    in the seetings>apps you can get to "disabled" tab via swiping
    google+ was there.
    i re-enabled it and the photo tools were back!
    thanks a lot man!
    nadxtreme likes this.
  5. jkbhso3
    Jelly Bean Aug 4, 2014
    jkbhso3 , Aug 4, 2014 :
    No problem. Not sure what Google+ has to do with photo editing but that's the problem. I don't even use Google+ but we have to have it enabled to set wallpapers.
  6. joshi.bhargav.66
    Cupcake Feb 14, 2015
    joshi.bhargav.66 , Feb 14, 2015 :
    hi Guys
    i have very strange problem.
    when i try to edit any photo from default edit tool it says you have to download tools.
    when i try to download it, it says download tools is presently not available.
    how do i get reed of it... Plz Help....
    Thanks
    Bhargav
  7. Dodkrake
    Ice Cream Sandwich Feb 14, 2015
    Dodkrake , Feb 14, 2015 :
    What? I don't even have google + installed and it's for sure not turned on, and I have photo editing and wallpapers.
  8. jkbhso3
    Jelly Bean Feb 14, 2015
    jkbhso3 , Feb 14, 2015 :
    Google+ is required for the stock editing.
  9. Dodkrake
    Ice Cream Sandwich Feb 16, 2015
    Dodkrake , Feb 16, 2015 :
    Shall I take screenshots?
  10. Amberghini
    Cupcake Apr 28, 2015
    Amberghini , Apr 28, 2015 :
    I can confirm that this is the correct fix. I've been having the exact same issue. Re-enabling the Google+ app that I had disabled when I got my OPO instantly fixed the problem.
  11. rampeled
    Cupcake Jun 2, 2015
  12. script
    Moderator Moderator Jun 2, 2015
    script , Jun 2, 2015 :
    I read, that the new Google photos app has a limited editing tool! Can anyone confirm that?
    PRK.R likes this.
  13. harp666
    Cupcake Jun 23, 2015
  14. qadimuj
    Cupcake Jul 9, 2015
    qadimuj , Jul 9, 2015 :
    Can someone give clear instruction on how to disable and enable Google +?
    I'm reading this thread and try to do it but how on earth do I need to do it?
    My photo editing tool is gone and it has been replaced by something is a lot worse compared to the ordinal one...
  15. qadimuj
    Cupcake Jul 9, 2015
    Now I get only this. A lot less options to edit a photo. Really miss the ordinal editing tool :(
  16. jaburge1
    Cupcake Jul 22, 2015
    jaburge1 , Jul 22, 2015 :
    I too lost the original photo editing options once I started using Google Photos instead of the default Gallery app. I want the original options back really bad! Please help
  17. jaimin1109
    Cupcake Aug 5, 2015
    jaimin1109 , Aug 5, 2015 :
    frnd cant find the google+ in setting-apps no broo!!!
  18. jaimin1109
    Cupcake Aug 5, 2015
  19. Deactivated User
    Aug 11, 2015
  20. Panache
    Cupcake Aug 11, 2015
    Panache , Aug 11, 2015 :
    If you're still facing the issue, please uninstall Google plus updates. This will replace the google+ app with its factory version. This works for me. Every time I see the options like above in your screenshot I simply go to settings > apps > Google+> uninstall updates and when you go to edit a photo it might give you options based on the availability of photo editors on your phone. In mine I see photos Google+ and photos photos.. Simply select photos Google+ and you will see the options that you wanted. Hope this works for you as well. Cheers.
