OnePlus One insufficient system storage
  1. Silvered
    Gingerbread May 29, 2016
    Silvered , May 29, 2016 :
    Hi guys,
    when i install a custom rom (like cm13) i get a strange error. The room boot but the system storage is insufficient, i can't install the gapps also (opengapps full version). I have already tried flash by fastboot but i get error like "unfortunately the process SystemUI has stopped".
    What can i do to fix it?
  2. pablofg1978
    Head Moderator Head Moderator May 29, 2016
  3. Oschara
    Oschara , May 29, 2016 :
    Try installing Pico gapps
    AntMunny likes this.
  4. malidan
    Nougat May 29, 2016
    malidan , May 29, 2016 :
    Strange one, I have not seen that before. Do a full wipe, maybe even reformat your partitions 1 by 1.
    Good luck
  5. Lancelot_69
    Lollipop May 30, 2016
  6. se7enlyn
    Ice Cream Sandwich May 30, 2016
    se7enlyn , May 30, 2016 :
    i have encountered this problem once while trying to install exodus 6.0 with opengapps full. it won't accept this version of opengapps. no such problem when i install other roms like sultan's cm 13 with opengapps full.
  7. Silvered
    Gingerbread May 30, 2016
    Silvered , May 30, 2016 :
    The gapps mini or pico are installed but the system space continues to be insufficient. I can't even do the screenshot
  8. Silvered
    See the reply to Lancelot_69
  9. Silvered
    Did it. It worked but wheb i tried to install a custom ROM the issue persists
    GongYin likes this.
  10. Jac_Q
    Jac_Q , May 30, 2016 :
    Did you probably flash the wrong UserData .img file? There are different ones for the 64GB and 16GB version.
  11. Silvered
    I flash the userdata_64G.img
  12. malidan
    Nougat May 30, 2016
    malidan , May 30, 2016 :
    Do you have the latest version of Twrp? There could also be something wrong with the zip, try a rom that you have installed before without any issues to check this.
  13. Silvered
    Yes i have TWRP 3.0.2-0, the zip is correct because the issue presents with every rom or gapps
  14. malidan
    Nougat May 30, 2016
    Rather then mess about I would get the OPO an factory image and flash it using the recovery tool or manually through fastboot this will restore the, device to factory condition repairing the partitions.
    This use to be a common issue back in the day corrupted partitions, so this will almost certainly work.
  15. daniga74
    Jelly Bean May 30, 2016
    daniga74 , May 30, 2016 :
    compared to CM snapshot (329MB) the last few nightly increased the size (365MB), now they include gello browser
  16. cobernick
    Cupcake Jun 8, 2016
    cobernick , Jun 8, 2016 :
    Hi,
    I think I have a similar problem here.
    I made a factory reset of my OPO earlier because I have the issue whith the lock PIN on encrypted phone when upgrading to COS13. I sideloaded COS12 and worked with it for a few weeks and then tried to upgrade again. I made the reset after the upgrade, when my PIN (for encryption) didn't work.
    So now I'm on COS13 but the storage shows only 2.9GB (my OPO is a 64GB). I tried another reset but it's still the same.
    Problem SOLVED after recovery.
  17. CyborgHA
    Ice Cream Sandwich Sep 12, 2016
    CyborgHA , Sep 12, 2016 :
    It's in italian but I can traslate...
    https://forums.oneplus.net/threads/...tizione-system-su-oneplus-one-e-altri.460348/
  18. sbtkd85
    Honeycomb Sep 13, 2016
  19. IMOnTrip
    Donut Jun 12, 2017
