2
OnePlus One stuck in Bootloop!!
  1. jenish112
    Gingerbread Oct 28, 2017
    jenish112 , Oct 28, 2017 :
    So I have been using RR rom on my OnePlus One since long now. I am running RR-N-v5.8.5-20171020 on my device right now. Today suddenly phone restarted and it wont go beyond resurrection remix boot animation. How can I sort this out? I don't want to lose my data (including app data).
    Things I tried till now but didn't work:
    1) Tried clearing cache & dalvik cache and restarting but it didn't work.
    2) Tried re-installing RR same version but it also didn't work.
    PS: I can enter into recovery mode and fastboot mode.
    Update 1:
    It worked for for few days after factory resetting and install OS again.
    But the problem started again and a new problem has started. While trying to install OS from twrp device restarts. Not able to install OS also now.
    And now it wont even go to TWRP keeps restarting at initial OnePlus Logo powered by android one.
    Any help or suggestions?
    Update 2:
    Replaced the battery and everything seems to be working fine.
    the_reckoner and theOPlover like this.
  2. WorldPeace.4.ever
    WorldPeace.4.ever , Oct 28, 2017 :
    You can't expect that kind of a stability from a custom ROM.
    As for your problem, either a partition is corrupted or a hardware component has failed. Therefore according to me the only thing you could try is to fully drain the device and charge it to 100 percent again if you don't want to loose any data.
    Good luck
  3. nobelium76
    KitKat Oct 28, 2017
    nobelium76 , Oct 28, 2017 :
    I beg to differ on the stability. LineageOS, RR, etc have been around since the beginning and are very stable.
  4. jenish112
    I don't think hardware component has failed as recovery mode and fastboot mode is working perfectly fine.
    Yeah will try draining the battery & charging it to 100% before restarting. Hopefully it works.
  5. jenish112
    Totally agreed. Every since I shifted from COS to RR I never faced any problem. The ROM is very much stable and reliable.
    nobelium76 likes this.
  6. Adnan.TechMe
  7. jenish112
    The one I have installed is the newest version of ROM. Won't flashing older version create some problem?
  8. WorldPeace.4.ever
    When you use a custom recovery with a custom ROM and mods then it doesn't remain perfect, glitches and problems tend to happen more thus making it unstable.
  9. WorldPeace.4.ever
    Actually even if the recovery or fastboot are working it doesn't mean that hardware is fine as they don't need access to all the components of the device.
  10. nobelium76
    KitKat Oct 28, 2017
    To a degree, but considering the time all of the above has been working on bacon its pretty solid. LineageOS and derivatives are very stable. OnePlus One shipped with COS, which was based on CM, which became LOS. Not OOS, though later builds might have shipped with a beta in India ..can't remember to be honest.
    jenish112 likes this.
  11. elanglois
    Lollipop Oct 28, 2017
    elanglois , Oct 28, 2017 :
    No, no, and NO
    WTF does your battery have to do with a bootloop?
  12. elanglois
    Wrong. Custom ROMs are often more stable than OOS
    jenish112 and nobelium76 like this.
  13. elanglois
    Wipe data. Media files on internal storage will remain. Set up as new (clean flash), reinstall apps.
    You can experiment with making a nandroid backup before wiping and maybe it wont restore the problem. Shouldn't take long.
    jenish112, nobelium76 and Lancelot_69 like this.
  14. Lancelot_69
    Lancelot_69 , Oct 28, 2017 :
    Totally agree with this!
  15. jenish112
    So if I do a nandroid backup than while restoring does apps automatically gets restored or do I have to install all the apps manually first and than restore nandroid backup?
  16. elanglois
    Lollipop Oct 29, 2017
    elanglois , Oct 29, 2017 :
    nandroid will save and restore your apps and data. Don't save system settings/apps in the nandroid
  17. Adnan.TechMe
    Gingerbread Oct 29, 2017
    Adnan.TechMe , Oct 29, 2017 :
    no it won't. I guess the zip you're trying to flash is either corrupt or corrupt af.
    if you would like to keep your data, the only alternative is to dirty flash an older version of the same rom
  18. jenish112
    jenish112 , Oct 29, 2017 :
    I don't think the zip is corrupted as it was working fine since 7-8 days after flashing.
    Tried flashing an older version that also didn't work. :(
  19. jenish112
    Thanks man will give it a try.
  20. Copperstone77
    Froyo Oct 29, 2017
